Old 01-02-2019, 08:15 AM
Wypipo Wypipo is offline
Default Removing rust from chassis
The cross member on the back of my chassis has some rust. It?s right in front of the linkage. The cause was the mount for an SXS skid plate which is a metal hook that goes around the chassis that chipped the paint away. The rust spot is hard to get to, it?s on top of the bar under the motor. I didn?t plant on taking everything off the chassis this winter, any ideas on how to get to it and fix it? If I have to take everything off I will but didn?t plan on doing that until next year.
File Type: jpg 05072E6A-CB92-4D92-82F9-2F1A38F368A5.jpg (75.7 KB, 37 views)
File Type: jpg 1E604D98-2A1F-41E8-970C-40A8EEE18986.jpg (76.0 KB, 39 views)
Old 01-02-2019, 01:46 PM
GASGASCWB GASGASCWB is offline
I have the same problem with ENDURO ENGINERRING SKID PLATE!
Try to put a tape around the chassis...
I try to do that this week and and I say here if it worked!
Old 01-02-2019, 05:12 PM
After you have removed the rust (mask off and media blast, or use abrasives) and sealed it (paint?), I would apply some quality two part epoxy around the frame rail to prevent future abrasion. Re-apply as necessary.
Old 01-06-2019, 03:34 PM
I?m not sure if it was from the metal hook vibrating, heat transferring from the engine to the hook, or a combination of both. My solution was to cut the plastic hook off of the stock skid plate and drill holes in it to mount to the SXS skid plate. I will also use some 2 part epoxy on the chassis after I get that taken care of.
Old 01-09-2019, 08:53 AM
risk74 risk74 is offline
I've suffered the same problem on all my frames, whichever skid-plate I've used. I now cut strips of old radiator hose and safety wire it to go between the plate and the frame. The curve of the hose fits the curve of the frame nicely. Seems to help the paint hold up better, but I think eventually that area is always going to suffer from the issue, given the abuse it sees.
Old 01-29-2019, 08:01 AM
dzhitshard dzhitshard is offline
The paint comes off of every offroad bike in that spot because dirt gets between the hook and the frame and gets ground in with vibration and impacts. It will happed with the jimmy rigged plastic hook as well.
The hook replacement is a bad idea. It will likely cause you way more headaches than a little surface rust that isn't hurting anything but show bike value anyway.
Plastic frame hooks are junk and that's why every "economy" junk plastic skid plate has them instead of machined aluminum or derlin one. When they fail they tend to cause more damage as the skid plate gets ripped off.
Your top of the line SXS glide plate has that machined aluminum frame hook for a reason.
PS, I've done the tape thing and it's no better. The sand can't wash out of it after it's ground in to the tape so all you have done is put sand paper between the frame and clamp.
I've also done the hose wrap which brought about it's own issue of then making a gap between the belly of the skid plate and the frame rails. I hated the clank or slap sound that made every time I made contact with a rock etc.
In the end I just decided that the little wear on the frame is going to have to be accepted if I'm going to ride the things off road.
Old 01-29-2019, 11:32 AM
RudolfHucker's Avatar
In the UK there are 2 products I would use for this issue. Not sure if there is availability or an equivalent where you are.
The 1st is Jenolite that is a rust cure that chemically stabilizes rust. You paint it on and let it get on with it.
https://www.jenolite.net/
The 2nd is Hammerite paint that is very heavy duty and can be put directly onto bare metal without needing a primer. It's as durable as epoxy paint without being anywhere near as brittle.
https://www.hammerite.co.uk/
I used a lot of Hammerite on a Beta 300RR that had paint that was as durable as donkey snot. The Hammerite colour was a very good match for the original Beta red.
RUST MAGAZINE #21 BMW 1200 Stipped Down Off Road Bike Moto7man General Discussions & Announcements 0 01-27-2017 10:56 AM
Frame Rust! :( Steve-A Enduro Chassis & Body 6 07-07-2015 12:29 PM
Pipe surface rust removal? liv2day Enduro Engine - 2 stroke 11 04-02-2014 11:27 AM
Chassis set up .... skid jackson Enduro Chassis & Body 2 11-28-2011 10:55 AM
Rust on my shock Gonzo Enduro Suspension 3 08-30-2006 01:29 AM
