"Wanted to Buy" & "Want To Trade" Bikes or Parts |
Desperately Need Left Radiator and Cap 04 EC300
Just finished second in my first race on the EC300, somehow damaged left rad and cap. Paypal waiting, need these ASAP. Thanks.
Kris Larrivee VCHSS #74p
Sponsors: http://www.evolutionsuspensionproducts.com/ http://www.sportbiketrackgear.com/ Blog: http://www.speedofarrival.com/ |
http://www.ebay.com/itm/ALUMINUM-RAD...5UPNw3&vxp=mtr
I think the cap is interchangeable with a ktm... Folks used to use ktm with higher pressure, etc. Radiator repair places are available that will fix even a very contorted radiator... Just search "motorcycle radiator repair" on google.. A quick search found this one on east coast... http://icwradiators.com/icwradiators.com/Home.html jeff
Myler's does great work. Also has replacements.
Myler's doesn't have them listed for the 04 model, 07 is the earliest listed. Anyone know if they are the same?
I don't think they are exactly the same, but I do believe you will be able to use it. I haven't tried it myself, though.
Anders "So you know, that you're over the hill when your mind makes a promise that your body can't fill" (Little Feat: Old Folks Boogie) 2015 EC200 Racing: TE bars, Rekluse Core Exp 3.0, 38mm Lectron & Ohlins S3 steering damper 2006 EC200: 2011 plastics, Rekluse Z-Start, revalved KYB forks & Scotts steering damper 1998 Bimota Supermono 1986 Duc Mille S2 1975 Guzzi sidecar hack 1961 Morini Corsaro 125 etc |
I just tried to fix a hole in my 10 radiator - the guy that did the work said the ktm cap does not fit so confirm this for your model before buying a ktm cap
I have a spare pair I bought on here a couple years ago but never used. One of them has a braise repair but they don't leak.
