Old 07-06-2014, 03:14 AM
Nicolas89 Nicolas89 is offline
Default ec125 -01 power valve issue?
Hello. new here on the forum.
I've just bought a 2001 125 ec for my girlfriend to start riding.
It runs nice at idle but very bad as soon as you open the throttle, but if i twist the throttle wide open it hits hard and revs out nicely.
My latest idea is about the power valve so i post this video to get your opinion,
is this power valve moving properly?
https://www.youtube.com/watch?v=-T-P...ature=youtu.be
thx
Old 07-06-2014, 03:23 AM
savage sausage's Avatar
savage sausage savage sausage is offline
Default hi
It's difficult to see from the video, but if it goes does not movefrom stop to stop then it might be worth taking off the exhaust, and moving it by hand whilst looking in the exhaust port.
have you got the bike jetted correctly, spark plug ok?
Old 07-06-2014, 04:24 AM
What jetting and spark plug is recomended for a beginner? Fmf silencer
Old 07-06-2014, 06:03 AM
I'm no jetting expert the resident jetting/carb expert is jakobi give him a shout .
firstly how does the bike start?? low range/mid range/ wot ??
take apart the carb and look at the pilot jet / main jet and needle what position is the clip at also what does it say on the needle.
are the reeds ok?
like I said jakobi is a good guy and will be able to steer you in the right direction
Old 07-06-2014, 06:30 AM
No first hand experience with a 125, or a GG of that vintage. Not sure the PV action looked all that good to me though. Suggestion would be disconnect the arm to the PV and make sure the valve moves as it should in the cylinder. May be a bit carboned/gummed up.
I don't like to suggest hooking into jetting as you'll waste your time if the engine isn't mechanically correct to start with.
Old 07-06-2014, 06:38 AM
It starts nice. Good at idle. Have been messing with the jetting. 45. 180. N1EG in the middle #7 throttle is the current setup. The power valve parts in the cylinder moves easily. But the spring of the governor thing feels kinda stiff..
Old 07-06-2014, 10:20 AM
thejackrabbit thejackrabbit is offline
you shouldn't run the bike with the expansion chamber off, I would put the full exhaust system back on and see how the power valve reacts. no exhaust may be causing it to rev slowly
Jack - western PA
2006 KTM 250 sx
2006 EC 200/ 11' style kit--GONE
2004 200 EXC
1997 KDX 220
2004 CRF 250X
1974 CL125
www.youtube.com/allthatstuff35 <---some gasgas videos here
Old 07-06-2014, 10:23 AM
Hard to see with it on
Old 07-06-2014, 10:35 AM
Neil E. Neil E. is offline
Run it with the left side powervalve cover off and watch how the shaft turns. See if the amount of rotation matches what the travel on the right side would be. Also watch to see if it rotates smoothly.
Old 07-06-2014, 11:41 AM
Theres no left side cover on the 125cc
Any opinions about the jetting?
EC125 Power Valve and Oil oldschool07 Enduro Engine - 2 stroke 11 09-27-2015 02:34 PM
S3 cylinder/power valve help? '11EC300 Enduro Engine - 2 stroke 7 06-02-2014 08:18 PM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
power valve nut bonkeye Enduro Engine - 2 stroke 4 10-11-2012 06:40 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
