Old 05-10-2012, 11:57 PM
bones150 bones150 is offline
Default 2012 300 float height?
What is the float height supossed to be. I have seen 6mm to 20mm. Have not even looked yet but need to know to set correctly or at least cheek. Have her pretty lean and she is drinking fuel pretty good. Maybe normal? It is not puking fuel out the carb so I know it is not way to high.
Old 05-11-2012, 12:44 AM
nato nato is offline
What jetting are you running in yours? I have mine at 42p n3cj#3 175m
Tilt it over and see if fuel leaks on the ground and you should get 45 degrees of tilt. You want the seem of the float just off level with the carb mount face.
Old 05-11-2012, 12:53 AM
40 pilot jd needle red clip 3 and 170 main.
Old 05-11-2012, 02:04 AM
http://www.gasgasrider.org/forum/sho...ighlight=float
float bowl height on 2010 300??? nambo-trev Enduro Intake/Carburetion - 2 stroke 4 06-19-2011 01:08 PM
Oil height wence Enduro Suspension 16 03-14-2009 04:08 PM
Fork oil and height JCW Enduro Suspension 5 11-24-2007 10:12 PM
Float height ??? bens25au Enduro Intake/Carburetion - 2 stroke 3 08-01-2007 04:28 AM
Gas Gas Seat Height GregM Enduro Chassis & Body 4 07-20-2006 02:02 PM
