#11
My bike has been having the same symptoms as yours. I thought it was the carb jetting. But after 4 hours of carb in carb out etc. My friend came over and suggested it wasn't the carb as it was back firing through the air box suggesting it would be an electrical fault. 5 mins later stator off and it was clear 1 coil was hanging loose off its spline 4 others where black and floating loose inside there wrap. But I can't find a replacement stator other than the oem part at just under ?400 for a 2005 bike it's a bit rich.
GasGas Not Ass Gas.... No more KTM EXC'uses... www.scunnybikers.com @Ktmandy |
#12
The cure was,
New HT coil and new CDI. Looks like the new HT I'd fitted was buggered from the get go!
2006 EC300 Enduro - Ignitech CDI - 38/NECW#2/165 FMF gnarly, FMF shorty, .50 front 5.7 rear 2016 RM-Z450 |
Sputters at high revs... | motopsycho87 | Enduro Electrical & Wiring | 9 | 06-21-2013 10:12 PM |
Power drops with revs | swazi_matt | Enduro Electrical & Wiring | 0 | 10-09-2011 05:52 AM |
Max revs when starting up. | Todd5774 | Enduro Intake/Carburetion - 2 stroke | 4 | 01-24-2010 08:22 AM |
EC300 Revs when cold-started | stevethebrit | Enduro Intake/Carburetion - 2 stroke | 6 | 07-10-2009 11:04 PM |
Revs from hell -- stuck throttle or bad mojo? | AZRickD | Enduro Intake/Carburetion - 2 stroke | 25 | 01-21-2009 08:54 PM |
