Old 08-14-2020, 03:34 PM
dimtsam dimtsam is offline
Default GAS GAS Trailtech Vapor Speedometer sensors
Hello everyone
I got a GG EC 250 2011 and there ' s a Trailtech Vapor on it. But the cables are cut off. And there are no sensors...I need help to identify the cables coming out of speedo. I know which pair is the Power.
The engines temperature sensor has 4 wires? Can I replace this sensor with an other except Trailtech's because I think is too expensive?
Is there a cable that goes to spark plug?
I need any info that you can give.
Thanks a lot
Old 09-11-2020, 02:31 AM
After contact with TrailTech I finally found out the answer. So I'll try to put some infos here in case someone else need this.
The speedometer
Old 09-11-2020, 02:44 AM
The first cable from the left with the connector is connected to Power 12v. The second is for tachometer sensor. The third, which is red marked, is a 4 wire cable that is connected to remote switch (which is no longer available). The last cable is for engine temp sensor.
2007 Ec 300 speedometer Jonas300 Enduro Electrical & Wiring 4 04-29-2018 03:12 PM
2011 xc 300 odo/speedometer ? Muddy General Discussions & Announcements 48 07-22-2013 10:38 AM
Wanted: Enduro Computer (Trailtech/Vapor). Lots Of Bike Parts To Trade. flatout111 "Wanted to Buy" & "Want To Trade" 3 04-21-2013 08:32 AM
Problem with Trailtech Vapor on 2011-EC300e erniebearskin Enduro Electrical & Wiring 2 05-20-2012 08:53 AM
Vapor Trailtech darren United Kingdom 8 07-22-2009 01:05 PM
