Old 07-21-2011, 11:21 PM
fire1998 fire1998 is offline
Default 2011 EC 300 jetting for 5000-7500ft??
Just became a member of the GasGas club. Bought a 2011 EC 300. What are you guys running for jetting for higher altitudes 5000-7500 ft? Should I just buy a JD Jetting kit and call it good?
thanks
Old 07-24-2011, 10:00 PM
RockyMtnGasGas RockyMtnGasGas is offline
I just ran my '03 MC 250 for the first time at 7000 ft outside of Denver with the JD jetting kit. 168, Red needle 3rd position which is recommended on the kit. It is about 95% of the way there without doing much else. Another guy in town ran it as well with great results reported.
Old 07-24-2011, 10:51 PM
husley's Avatar
husley husley is offline
Bronze Level Site Supporter
2010 300. 4-8000' 55-80'F
I was just gonna get a JD Kit like I have countless times in the past but decided to do it myself after snooping around this site
38, N3CH #2, 175. Have had great luck with this jetting, and a thank u to those who helped. Can get about 70 miles a tank
There are a couple great threads on the site
2015 KTM 450 XCW
2014 350 XCF Wife's
2009 200 ec. Loving it
2007 Beta Rev 3 270
2007 KTM 200 XC Wife's
Public Lands belong to the Public
Old 07-31-2011, 03:29 PM
gasser's Avatar
gasser gasser is offline
Just got back from Salida,CO. We rode from 7,000 to 13,000 feet and my bike ran fine off the bottom and on top but was rich in the middle to the point I was getting a good amount of spooge I shouldn't have had. Never fouled a plug, never got hot even on long, hard, technical climbs that required constant clutch slipping. Mileage was over 25mpg (65-70 per stock tank) My 07 300 got over 30mpg last year but it had the RB head mod.
2011 ec250E 36mm carb N3CH 2nd clip from top #7 slide 165 main 42 pilot
Old 08-02-2011, 06:13 PM
Default Jetting
Going thru my jets and needles I found a DDJ, N1EC and a blue JD jetting needle for a Husky WR 300 with a PWK carb on it. Will any of these work?
Old 08-11-2011, 01:09 PM
dualsportutah.com's Avatar
dualsportutah.com dualsportutah.com is offline
Default 4000-and up Jetting for GasGas 2011 ec300
Here in Moab on my 2011 ec 300 38mm carb I found that n3eh in middle 148-150 main and 40p with 80-1, 2oz oil per gal the bike rips great .
the n3ch is the same just as n3eh its just 1/2 clips sizes apart
Old 08-11-2011, 01:18 PM
Default Spooge
You can run the GG @ 100/1 but I wont go there 80/1 works great I just had the top end off to check it out lots of oil in the piston rist pin area rings piston and cylinder look like new 1500 miles on it 148m 40p n3eh
Old 08-29-2011, 12:15 PM
Called a local dealer and he suggested a stock YZ 250 needle in middle clip along with 160 main. Pilot is a 40. Rode it around the neighborhood and it seems like its working. Will be awhile til I get her in the dirt. Ill report back
Old 08-29-2011, 07:31 PM
Thats a small main mate. I'd be very careful going that small unless if you have a 36mm carb. That would make more sense.
I'm running a YZ needle. N3EW at clip 2 with a 42 Pilot and 178main which I will drop when it warms up some more.
25C+ / 80F+
300M /1000FT
Old 08-29-2011, 08:08 PM
coachtech coachtech is offline
I'm running a 152 main with DEP sudco needle, third clip in a 36mm carb(2011 ec300)....90 hours.
Little higher elevation....8000'-13000'
jz
2011 125 6 days jetting orangezuk Enduro Intake/Carburetion - 2 stroke 11 04-28-2011 11:09 PM
2011 SixDays 250 JD jetting (YZ kit) thumperrider1 Enduro Intake/Carburetion - 2 stroke 3 04-24-2011 08:04 PM
2011 jetting mikemoto General Discussions & Announcements 7 01-22-2011 03:16 PM
5000-7000 ft. above sea level (jetting) Link Enduro Intake/Carburetion - 2 stroke 7 03-25-2008 01:45 PM
05 EC300 jetting for 4-5000 ft dhally Enduro Intake/Carburetion - 2 stroke 1 07-05-2007 06:04 PM
