Old 12-09-2011, 06:23 AM
nato nato is offline
Default Clutch fluid! Help please
While my brother was doing a bit to my bike the other day he had to bleed my clutch and he only added 30mm of oil but he used brake fluid now i am wondering is this a bad thing or or is it fine to mix this with whatever oil is already in there? Cheers Nato.
Old 12-09-2011, 07:34 AM
gasgasman's Avatar
The brake fluid will cause the seals to swell. You can try draining all the fluid and flush with brake clean.
Old 12-09-2011, 07:40 AM
yep bad thing to do, hopefully the 30ml will not cause too much effect diluted, you need to use mineral oil (5W fork oil works fine!) in the clutch
2003 txt250 Pro
2013 Ossa 280i
Old 12-09-2011, 08:01 AM
Thanks fellahs will get him to dump it out tomorrow. Maybe i can flush it with baby oil?
Old 12-09-2011, 09:02 PM
jostby jostby is offline
you don't say what year bike you have. Some years used brake fluid and some mineral fluid. It says what to use on the reservoir lid. You absolutely can't mix the two.
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 12-09-2011, 09:24 PM
lankydoug lankydoug is offline
If you mix brake fluid with oil or the reverse there is a 100% chance that all the rubber seals and hoses in your braking system will be compromised or ruined. Depending on how much you got in the system and how long it stayed will determine how quickly all the rubber parts will fail. Not maybe but will fail.
You must flush the entire system with alcohol and then replace all the rubber parts. The residue of oil will keep doing damage if you don't get it clean.
Sorry to bear the bad news
Old 12-09-2011, 10:55 PM
Its a 2010. If the orings are buggered i will know this by the clutch failing?
Old 12-10-2011, 03:35 PM
What does the reservoir cap say? I think mineral oil was only used for a couple years (in the clutch only). Think your 2010 uses brake fluid for the brake and clutch reservoir.
And yes, mixing brake fluid with mineral oil will cause the o-rings to eventually swell and fail.
'00 XC250 (mine)
Old 12-10-2011, 05:09 PM
TNT Cycle TNT Cycle is offline
my 2010 300 is mineral oil...I believe like many things with hydo clutches companies changed from time to time and from one to the other. Ktm had many combinations over the years...
Track-N-Trail Cycle LLC
trackntrailcycle.com
2011 Beta 400 RR (sorry )
2010 GAS GAS XC 300
2007 KTM 200 XC
Old 12-10-2011, 05:42 PM
I got it 2nd hand and it has an aftermarket cap on the resovoir so id be thinking that i should go with mineral oil like the rest of the 2010s
Clutch Hydraulic Fluid ? biggstr6 Enduro Other... 27 07-01-2014 11:38 AM
Clutch... Brake fluid? roostafish Enduro Chassis & Body 6 12-13-2009 04:13 PM
Clutch fluid change Wellsy Enduro Engine - 2 stroke 7 06-28-2008 03:44 PM
hydrolic clutch fluid rupecopp Enduro Chassis & Body 2 10-02-2007 06:29 AM
Hydraulic Fluid for the clutch lukachuki Enduro Engine - 2 stroke 2 09-22-2007 05:59 PM
