#31
N3CH
That blubber sounds like my 300 when it was stock |
#32
Yep. Mine does something similar, but it doesn't last as long as yours, as it cleans up quicker. It just on the bottom as I spool up the revs. The only thing I'm not happy with so far is the crappy footpegs. Mine broke on the second ride on a light tipover on a loamy hill.
GasGas, give me a new set of the stronger pegs like those that come on the cervates/nambo models.
2018 XC300 |
#33
Anyone think there is a possibility this spudder is ignition related? (bad mapping in the blackbox) Mine is much worse in rain mode. I desparately seek an answer. I cant drop the main jet any smaller as my bike acts lean after extended wot.
#34
maybe its a PV thing. Have you tried a CCK needle? Worked wonders for me.
#35
http://www.motocross-atv.com/Scar-St...r1620-0824.htm They sit slightly further forward than stock but otherwise they work great. Steve |
#36
Randall, you might be on to something. Did you get those other mods done?
Thanks for the link Steve. I actually just picked up some moose hybrid 1/2 inch back offset pegs. Probably going to put a hammerhead shifter on with the offset to get the shifter extended a bit. Even with the 1/2 inch back it's still a tight fit, even with my size 8 Gaerne's. These gasser levers are a little short.
2018 XC300 |
#37
Mine came with 1.3mm of gaskets with 2.6mm of squish.
The gasket stack was perfect to set the exhaust port flush with top of piston at BDC. I didn't want to change port timing to lose top end so went with a high comp head which increased compression and reduced squish. I may drop the 0.3mm gasket next top end to see how it effects the engine characteristics. |
2011 SixDays 250 JD jetting (YZ kit) | thumperrider1 | Enduro Intake/Carburetion - 2 stroke | 3 | 04-24-2011 08:04 PM |
2011 300 SixDays Set Up Advice | AZRickD | Enduro Suspension | 23 | 12-29-2010 09:17 PM |
Chilly tests the 2011 Sixdays | gasgasman | General Discussions & Announcements | 14 | 12-24-2010 08:34 PM |
EC300 SixDays 2011 | Elvis74 | General Discussions & Announcements | 10 | 09-17-2010 06:05 PM |
2011 GasGas Sixdays | noobi | General Discussions & Announcements | 38 | 09-02-2010 06:06 PM |
