Old 01-14-2020, 05:39 AM
eralha eralha is offline
Default 2018 EC 300 not running well
Hi,
Last ride my bike started running bad, like its in a rich condition, i didn?t change anything it just starter doing that after a hard ride.
Next morning e took it for a ride again and changed the spark plug, it got a little better but the problem maintained, at the end of the morning the problem got a little wrost.
Took it apart and cleaned the carb and check the reeds all seems good, the problem is still there, i'm thinking if it can be something on the cilinder or piston or even crank seals.
Can some one point me on the right direction?
Thanks.
Old 01-15-2020, 08:00 AM
Update:
Last night i took out the oil on the gear box, and i took about 850ml out, i had put around 910ml.
Does this mean i have crank seal leak?
Old 01-15-2020, 04:23 PM
fred99999au fred99999au is offline
You should be able to pressure and vacuum test the sealed bottom end and this will give you an indication is it is a crank seal.
Old 01-15-2020, 06:01 PM
You could also run some distinctively red ATF or tranny oil in the gear box and then pull the crank case drain bolt after running to see if there is any residual tranny oil in the crank case. If you do not run Dominator, or any red colored pre-mix....
Old 01-20-2020, 04:00 AM
Hi, just to give an update, the bike is working great again here is the list of what i dit i suspect that i didn't cleaned the carb well the first time:
- cleaned carb took out all the jiglers and cleaned with carb cleaner
- took out the ignition coil and sanded all the contacts on the frame and on the coil
Old 01-20-2020, 09:42 AM
Gald to hear you got her runnin' well again
Eye On Six Days up and running Berkyboy Off Road Racer's Corner 9 10-01-2012 02:50 AM
06-300 not running davedunaway Enduro Electrical & Wiring 11 08-29-2012 09:21 AM
03 300 not running tophat General Discussions & Announcements 22 08-23-2011 03:51 AM
Running hot Brian VT Enduro Engine - 2 stroke 9 10-01-2008 07:25 AM
Running In Dingo Enduro Engine - 2 stroke 3 07-26-2007 11:36 PM
