#21
I would be getting the top end off to check there's nothing else nasty going on. Clean and lube the whole power valve assembly so that you know that you are starting from a known good position.
If the piston looks OK, at least stick some new rings on it whilst you have the top off and give the crank a health check. Stick your finger down the end of the silencer and if it's very oily, repacking is easy and will give you extra benefits. The Castrol 2T oil you are using is good quality and I have used it for a number of years without any problems. Might be worth replacing the power bands, they can get a bit saggy over time. |
#22
Ask Doc 🤣
#23
More power | Upyourkiltbatman | Enduro Engine - 2 stroke | 10 | 01-08-2019 05:08 PM |
Loss of power - suspect power valve | Jonny Halls | Enduro Engine - 2 stroke | 4 | 01-22-2013 09:56 AM |
power now | Gassey fan | Enduro Intake/Carburetion - 2 stroke | 4 | 04-29-2010 12:08 PM |
200 power | nwrider | Enduro Engine - 2 stroke | 2 | 03-24-2010 09:26 AM |
More power in 250 EC | Henrik | Enduro Engine - 2 stroke | 5 | 09-24-2008 07:26 AM |
