Old 06-21-2013, 11:18 PM
AZRickD AZRickD is offline
Default Rick's New-2-Me 2011 EC250 Race Suspension Thread.
Extracted from the (last post) of the big suspension thread:
adv_rider is the former owner of my new-2-me 2011 GG EC250 Race:
He advises that the springs are stock.
adv_rider
I tried out this method. I split the difference and set it at 11mm. 18 COMP, 20 REB. I didn't check the hi spd. Being a brand new bike, I didn't measure the sag. I figured I would let the suspension break in, then take measurements.
I measured my sag(s) with the following -- street clothes, empty tank, with a 25-pound weight in my backpack. I weigh about 190 in street clothes.
Shock measurement:
Free sag (settling under its own weight for those not in the know): 36mm
Race sag = 108mm
Fork measurement:
Race sag = 43mm
While the free sag of 36mm might be a bit high, I'm of the mind to leave things alone for the time being, and go hammer some test whoops this weekend to see how it behaves.
Old 06-22-2013, 12:20 AM
twowheels's Avatar
adv_rider
Shock measurement:
Race sag = 108mm
Fork measurement:
Race sag = 43mm
The forks are likely going to want at least a 0.44 set of springs. Rear sag could stand to be decreased to 103-105.
Steven Beane #275
afterhourscycle.com
Old 06-22-2013, 01:39 AM
I would suspect that as well, but I need to prove it to myself, first.
One size up on the forks, perhaps. Lets see how they perform tomorrow. I wouldn't be surprised to see them be okay for me.
Do you think I'll need to go up one on the shock or can I crank the spring a bit?
Old 06-22-2013, 09:07 AM
Fastest way to a crappy ride in the rocks is a soft spring with a lot of preload. Those numbers seem almost too good for a 5.2 rear spring. I'm at 5.4 on my '07 and its borderline soft for me @ 176 lbs. The '12 likes a softer spring so a 5.4 is it.
Sent from my iPad using Tapatalk HD
Old 06-22-2013, 12:48 PM
Well, i dooo have my old spring from the 2005. I don't see a marking on it but LTR has some paperwork I filed away.
Old 06-22-2013, 01:35 PM
celler celler is offline
I agree with this. I'm 180 lbs and have 38mm free about 115-118 rider and 12mm spring preload. If I add anymore spring preload ride gets harsh. I ride rocks almost exclusively and do not carry tools on my body. If I rode a lot of sand and whoops heavier spings would be in order. Others on this site would give better guidance for whoops. The Michigan guys live in the sand.
On a separate note : I had a pair of 126mm LTR links and with them I can run more spring preload and the ride stays good. These links are on my 2005. I can set the bike up with 95mm rider sag with these. The Arizona terrain that I rode is similar to what I ride in the summer in Missouri.
Old 06-22-2013, 01:50 PM
twowheels's Avatar
I've got a couple of 5.6s if you want to give one a try. Like it and buy it or send it back postage paid.
Steven Beane #275
afterhourscycle.com
Old 06-22-2013, 02:01 PM
What fork springs go with the 5.6?
Old 06-22-2013, 02:07 PM
twowheels's Avatar
Typically 0.46
Steven Beane #275
afterhourscycle.com
Old 06-22-2013, 03:55 PM
Ahhh. I have found the LTR worksheet
...and I quote:
2005 GG DE 250
S.T. Trail/Enduro/H.S. ROCKS
200 pounds, Toolpack, hydration
FORKS:
Springs -- .44
Preload -- 6mm
Rebound -- 10 out
Comp Low -- 16 out
Comp Hi -- NA
Oil Height -- 130mm 10weight
SHOCK:
Springs -- 5.4
Preload -- 10mm
Rebound -- 16 out
Comp Low -- 18 out
Comp Hi -- 2.5 out
PSI 130mm -- 195 PSI
Shock Piston Height -- 10-15mm
Wanted: Stuff for my New-2-Me EC250 2011 Race AZRickD Parts 11 06-26-2013 06:01 PM
Today's powervalve thread - loose bolt screws race motogroove Enduro Engine - 2 stroke 3 07-29-2011 04:33 PM
2010 Sach suspension thread for noobs forgiven Enduro Suspension 8 02-03-2011 06:37 PM
Race Tech Suspension???????? Wicitup Enduro Suspension 9 11-25-2007 04:55 PM
FAQ in suspension thread?? Link Enduro Suspension 6 10-04-2007 05:47 PM
