Old 06-15-2019, 11:53 AM
adriano.ro adriano.ro is offline
Default Sachs shock ec 300 2010 crossover?
Is some shock crossover for my GG?
The clicks on this shock are there but with no effect....
Old 06-15-2019, 02:00 PM
Ohlins TTX will.
Old 06-15-2019, 07:34 PM
frankinberg's Avatar
Also a standard ohlins 888 cheaper than ttx
Old 06-16-2019, 02:27 AM
And those ohlins socks only from GG or can I find from other bike?
Old 06-16-2019, 06:31 PM
Ohlins 888 is for gasgas only should be able to find one one eBay make sure it's for a 07-11
Old 06-17-2019, 03:51 PM
you can also change to racetech gold valve. I think it is listed as husky 310, can have a look if you want?
Old 06-17-2019, 06:51 PM
Yerpp.. 888 or TTX from these years will fit.. Note that the exception is the 2011 Racing and Nambo/Cerventez models; they used a different linkage that carried into 2012.
Old 06-17-2019, 10:33 PM
Yes,tnx!
Old 06-18-2019, 04:51 AM
The kit you want is smgv 5043 (courtesy of Simmo)
It fits the 2009 husky te310
Old 06-18-2019, 09:09 PM
A new mid piston on the Sachs may work. Depends if the issue is the clickers not working due to air in the system, a lack of nitrogen pressure causing cavitation.. OR the old sloppy piston band on the Sachs.
If it's the later than the gold valve will surely improve things!
Sachs fork springs crossover IDAHOSPUD Enduro Suspension 13 09-27-2018 07:06 AM
2010-11 Sachs forks and shock wanted redrider "Wanted to Buy" & "Want To Trade" 3 12-20-2016 11:16 PM
2010 Sachs shock $75 tnttimber Parts 0 07-30-2016 05:37 PM
Sachs shock spring crossover? n_green Enduro Suspension 4 04-15-2013 04:27 PM
