Old 01-01-2011, 09:18 AM
jtgas jtgas is offline
Default 2011 300 six days shock
Let me first say I love my new 300, but I was wondering if anyone else has one with the ohlins shock that seems to be leaking. This is my 2nd shock i've put on it and it's leaking oil also.
Old 01-02-2011, 08:04 AM
Rod Overstreet Rod Overstreet is offline
How much ride time are you getting before the shock leaks?
Old 01-02-2011, 08:42 AM
It's leaking during 1st ride, at first I thought it was just oil from the factory but that's not the case. I'm going to ride again today and keep an eye on it. I also thought that it was gas from the vent tubes but it's just to much.
Old 01-02-2011, 09:01 AM
fury1's Avatar
fury1 fury1 is offline
you said you put on a 2nd shock,was that one a new one as well? hard to believe two new shocks could be leaking? i have seen a brand new husky rear sachs shock leaking oil on the trailer on the way home from the dealership,it does happen,but two shocks? your 100% sure its not coming from the overflow on the carb? where is the oil appear to be leaking from?
Old 01-02-2011, 12:22 PM
GMP's Avatar
GMP GMP is offline
Sometimes seal grease used for assembly works out down the shaft and looks like an oil leak.
Old 01-02-2011, 06:37 PM
The oil is 3/4 the way up the spring.
Old 01-02-2011, 07:44 PM
gasgasman's Avatar
Could be brake fluid.
The 6 days has that extended rear brake reservoir that make be leaking.
I would think if the shock was leaking fluid, you would notice a loss of action.
Old 01-03-2011, 12:14 AM
webmaster's Avatar
webmaster webmaster is online now
Administrator
The shock would also lose pressure and after it loses pressure then you don't feel the detent (clicks) when you turn the rebound adjuster.
I find it hard to believe you have two shocks leaking back to back - something else is going on...
Old 01-03-2011, 01:03 PM
I was yaking with my friend Richard at House of Horsepower this afternoon and mentioned your problem.
You said the oil was on the spring and not on the shock shaft right? Richard suggested you check your air filter, as you may have used to much oil. The oil runs off, drains thru the bottom of the airbox and down onto the shock spring.
Another good point is, if the shock sealhead was leaking, you would be experiencing a "pogo" stick effect. Is this happening when you ride?
Old 01-03-2011, 05:09 PM
I don't think that it feels like a pogo stick yet, I didn't get to ride much yesterday because I broke my foot peg. The stock air filter was pretty dry so I don't think that's the problem and I don't over oil my filters either. I'm going to check the extened brake reservior even though my brakes feel fine.
six days decals set dareuk United Kingdom 12 04-26-2011 03:35 PM
2011 250 Six Days danielm General Discussions & Announcements 31 11-24-2010 02:13 PM
300 Six Days dcg141 General Discussions & Announcements 22 11-22-2010 09:35 PM
Those were the days..... kim All Other Bikes... 3 02-04-2010 04:33 PM
SIX DAYS Gas Gas 250 jriley43 General Discussions & Announcements 10 03-09-2009 05:50 PM
