Old 01-12-2012, 01:38 PM
eaze_50's Avatar
eaze_50 eaze_50 is offline
Default 2008 EC Rear Caliper????
Does it have a part number on it? I have looked everywhere and have not located one.
Reason Being
I need to get a rebuild kit, and i'm trying to figure out which jap bikes used that same rear Nissin caliper so i can use my local shop for it. If any one knows what will crossover I would certainly appreciate it.
Also how much movement is there supposed to be in the caliper? The first inch of pedal movement on my bike seems to remove all the slack before it puts the squeeze on the disc.
Thanks
Old 01-12-2012, 07:38 PM
gasgasman's Avatar
Looks like it has air in the system.
I would bleed it real well.
It is too soon to need an over haul.
Old 01-12-2012, 10:09 PM
eaze_50's Avatar
It's bled that's when I discovered fluid coming from around the piston. You say it's too soon for an overhaul, what is usual? I've already had to rebuild the rear master cylinder.
Thread Tools
Display Modes
REAR CALIPER SUPPORT clearance Klausen Enduro Chassis & Body 1 10-22-2010 03:10 PM
rear caliper replacement wardy Enduro Chassis & Body 2 08-30-2010 08:07 PM
Rear Brake Caliper blitz11 Enduro Chassis & Body 11 10-28-2008 04:38 PM
