Old 10-23-2012, 06:27 PM
singletracker singletracker is offline
Originally Posted by jpelaston View Post
Did you ever get your axle to pull out easily? I have cleaned and greased to no end and still have to hit mine out with a hammer. Not good for me if I want to try to do any ISDE type tire changes.
I still have to tap on it until I get passed the bearing on the sprocket side. Other than it taking a little more effort to take the wheel on and off it seems fine.
Old 10-23-2012, 06:31 PM
GasGas's Avatar
GasGas GasGas is offline
It's possible that the aluminum spacer between the 2 left side bearings is damaged and catching the threads on the axle.
2018 EC 300
Old 10-24-2012, 01:05 AM
Rick's Avatar
Rick Rick is offline
I would pop out the bearings, and spacer. Then i would check to see it the bearings and spacer slides over the axle smooth out of the hub.
One or more bearings could not be seated squarely in the hub causing a mis alignment of the axle.
You may have a bad bearing on the drive side.
I make it a habit to pull the axles on a regular basis and clean and inspect. Stoch bite pads clean and polishing to ensure smooth operation.
Good luck
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 11-12-2012, 03:58 PM
Colemanian Colemanian is offline
Mine did the same thing. But it was a bear the ENTIRE way out. I looked at the axle, right about 1/2 inch from the thread was a ridge. I assumed that's was what was making hang up. I took a wire wheel and smoothed it out. Works much better now but still firm. Might give it a try.
Old 07-24-2013, 01:57 PM
john r b's Avatar
john r b john r b is offline
Default rear wheel bearings/spacer
Hoping some one can shed some light on this issue, While mounting a new rear tire on the 200. I noticed the axle needed to be driven out??
After inspecting the hub/bearings,I discovered the bearings are not moving
at all.Seems the Spacer is contacting the bearings. Ive taken a punch/hammer
to move the spacer over a bit but no luck,just marring the inside of the spacer.
Short of distroying the spacer are there options?? Thanks in advance.
John
Old 07-24-2013, 03:11 PM
Rick's Avatar
John,
Are talking about the internal wheel spacer in the hub?
Might not be a bad idea to just punch out the bearings and have a look as to what is going on. I just had mine apart last week. My rear wheel internal spacer has two "o rings" around it to help keep it centered in the hub so that when you insert the axle the spacer can't move and cause a binding issue.
I have also found that while pressing in the bearings I like to run my axle from the brake side through the bearing into the spacer and install in the sprocket side bearings with the axle in place. This method I have found keeps everything line up. The O rings really work nice in keeping the spacer centered within the hub.
It make things go super smooth if you heat the hub a little and use frozen bearings.
....good luck
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 07-24-2013, 03:40 PM
bergerhag's Avatar
The 2012 spacer is aluminium, if you torque the wheel axle too much it will deform and pinch the axle. Buy a new spacer. They are back running steel spacers again. I am not sure the aluminium spacer can take the specced torque either.
Old 07-24-2013, 09:51 PM
bkwdc's Avatar
bkwdc bkwdc is offline
Get the external spacers from http://www.checkpointoff-road.com/store.html and clean up the mushrooming from the internal spacer.
2011 EC300 Six Days
2010 EC300 Nambotin Replica
Old 07-24-2013, 10:08 PM
StuJohnson's Avatar
StuJohnson StuJohnson is offline
I personally don't have these but have heard they are not any better?
Someone on here should know.
Look for stainless steel ones. I think Moose Racing makes them.
http://www.mooseracing.com/products/...oductId=114464
2012 - XC 300 Racing
Seattle, WA
Thread Tools
Display Modes
rear axle Q nokturnal Enduro Chassis & Body 4 06-13-2012 11:52 PM
txt 250 1999 rear axle Rabbitist General Discussions & Announcements 0 03-15-2012 04:27 PM
450 wild rear axle bearings dogsbody Other GasGas Bikes/Quads 1 07-16-2009 11:03 AM
rear axle nut skid jackson Enduro Chassis & Body 2 06-17-2007 07:52 PM
Front Axle/Wheel Removal gasIdaho Enduro Chassis & Body 1 02-15-2007 09:31 PM
