Old 01-29-2013, 04:27 PM
prunty prunty is offline
Default 2003 EC300 Kickstarter
Just a quick question, I know there is loads of threads on kickstarters and swapping them for a YZ250 and so on, but in my case the pedal part of the kickstarter seems to have locked in the folded in position.
It's not seized solid and begins to fold out but only moves a wee bit and then goes no further. What is the issue here and is it repairable or is a it a case of having to replace it??
Old 01-29-2013, 05:39 PM
cbutler's Avatar
cbutler cbutler is online now
I would take it off the bike and disassemble it clean and grease it and see how it works. Make sure not to lose the ball bearing.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 01-29-2013, 07:58 PM
bowhunter007's Avatar
bowhunter007 bowhunter007 is offline
A buddy had this happen, while we were riding. We removed the kicker, pulled off the fuel line(let some premix fuel lube it a bit). Fixed for the day. At home disassemble, cleaned(the little ball bearing surface rusted), lubed, reassemble...ride.
All healed up, and ready to burn some fat.
Old 01-29-2013, 08:21 PM
jostby jostby is offline
yeah, soak it down good with some ATF and work it back and forth, should be good to go.
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 01-30-2013, 02:04 AM
I know how he felt. This happened to me while doing a Cross Country event on Sunday and I couldn't get the bike bump started, these events are usually hard enough to get around the circuit but it is much harder when the engine isn't running...
Old 02-02-2013, 06:45 PM
So this evening I decided to sort out this issue and the pedal worked like it should not seized at all. I don't know what happened between Sunday's event and this evening. Anyway I took it appart and greased the joint and all seems fine.
Old 02-02-2013, 08:09 PM
I have only had this issue with the GG kick lever. Once I swapped in a YZ kicker, it never happened again.
Old 02-07-2013, 06:40 PM
jdosher jdosher is offline
Ha! I had this happen to me as well - and I had an auto-clutch in at the time, so push starting wasn't an option. I found a similar solution; I used the small length of hose I carry in my pack to dribble some pre-mix on the pivot. My long term solution was to replace it with a YZ kickstarter and I haven't had any issues since. That stock kicker likes to bind up in wet conditions.
Longer Kickstarter EC300 stay_upright Enduro Engine - 2 stroke 12 12-11-2008 04:28 AM
2003 ec300 longstrangetrip Enduro Engine - 2 stroke 2 05-22-2008 09:19 AM
