Old 02-13-2019, 04:17 PM
dzhitshard dzhitshard is offline
Default 2018 Head o ring gaskets
Can someone confirm the head O rings are indeed parts 7/8 on the parts fiche?
I ordered an aftermarket head and I normally would like to install it with new o rings.
I went to order one and the parts fiche shows one O ring as what appears to be #8 but lists it as crank case reed gasket. The part number is no where close to #7 which is labeled as cylinder head O ring.
I want to make sure I don't order the wrong thing and have to wait and extra week.
Thanks
Old 02-14-2019, 02:19 AM
RudolfHucker's Avatar
7 and 8 are described correctly in the MY 2019 parts list, if that helps.
Old 02-14-2019, 06:19 AM
I'm not seeing a 19 model year drop down option on the 2 sources I know of for the parts fiche. If it's not too much trouble can you give me the part numbers your 2019 fiche shows?
Old 02-14-2019, 12:09 PM
ME25916060 for the outer.
ME30916065 for the inner. Assuming this is for a 300. The 200 and 250 inner is part ME25916065.
Don't quote me on this but I believe that the equivalent KTM parts fit if that is an easier option for you. I may be wrong.
Old 02-15-2019, 10:16 AM
Thank you.
yes the KTM part would be easier for me if I knew that they worked. I have a couple sets of those in the parts box. I just can't risk cracking it open and them not working this weekend. It looks to be a near perfect, snowless frozen ground course and I'd be really depressed if I missed it.
2018 ec250 piston and gaskets Wuzofoz Enduro Engine - 2 stroke 4 10-29-2018 05:45 AM
Re-use head gaskets/o-rings? Terrence R Enduro Engine - 2 stroke 6 04-01-2016 06:15 PM
Head gaskets, what's the trick? GGRider01 Enduro Engine - 2 stroke 9 10-11-2015 12:19 AM
Head o ring Dude Enduro Engine - 2 stroke 0 05-21-2011 09:28 AM
Head-gasket O-Ring question FFRDave Enduro Engine - 2 stroke 5 01-12-2008 09:56 AM
