Old 10-07-2008, 02:41 PM
iancp5's Avatar
iancp5 iancp5 is offline
Originally Posted by Skidad View Post
I checked some threads over on KTM Talk for their 200 and no mention of using the CCK needle. The 300 yes.
Here are the popular choices that seemed to come up the most (and JD needles of course).
CEK, CEL
DCJ, DCK
DDJ, DDK
Not sure if that helps or not but something to think about.
Skidad
Too much to think about! I'll have a look at the KTM site and see what they're saying.
My 300 came with an N1EF and the CCK was smoother so I was wondering if it works well in the 200. The other complicating factor is that currently it's fitted with a 36mm instead of the 38. When moving down in carb size what jetting changes should I expect to need? Currently it runs ok but not spot on. There is a power hole in the midrange. Not sure if rich or lean, I suspect rich. I guess dropping the needle a notch will soon tell me. It pulls then goes flat in the high midrange and then picks up again on full revs.
Old 10-07-2008, 03:18 PM
Skidad's Avatar
Skidad Skidad is offline
Yes have a look at their site to REALLY get your head spinning. I find it very interesting to compare the GG and KTM's in jetting as they seem to be quite similar with the same sort of issues.
The KTM 200's came with 36mm carbs for awhile also and most seem to be using a #6 or #6.5 (KTM weird thing I think) slide.
The guy Jersey Devil over there really knows the 200's so look at allot of his posts. There are others as well but he comes to mind. There is sooooooo much info your head will hurt after awhile.
I'll have to try the CCK in my 07 300 and also the N3EG? that Pobit recommended.
Skidad
Old 10-07-2008, 03:56 PM
iancp5's Avatar
Skidad
I thought it worked really well. Smooth but with no noticeable power loss.
Old 10-07-2008, 05:41 PM
2 strokes 4 life's Avatar
Bike year & model = 2002 EC250
Temperature (degF) = 10 to 30 deg C
Elevation (feet) = 1900-2600FT
Main jet = 178
Pilot jet = 42
Needle & notch = LTR #3
Air screw setting = 1.5
Throttle valve/slide = 7
Result: Mid is a bit rich but bike runs way too hot with the needle in #2 position. Bottom end is great.
2012 Ktm 300xc
2001 Gasgas EC300
Old 11-10-2008, 03:33 PM
Leo's Avatar
Leo Leo is offline
Bike year & model = 2005 EC250
Temperature (degF) = 68-104F (20-40C)
Elevation (feet) =2600 (800m)
Main jet = 180
Pilot jet =40
Needle & notch = NIEG 2ยบ from top
Air screw setting = 1 turn from closed
Results:
The Brazilian gasoline has 25% of alcohol. So this is the best we can.
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 12-18-2008, 01:29 PM
iancp5's Avatar
Default Ec200 2004
Bike year & model = 2004 EC200
Temperature 0-20C
Elevation (feet) = 0 - 500
Main jet = 178
Pilot jet =42
Needle & notch = N1EE #2
Slide = #6
Bit flat in the middle but could be the dent in my pipe.
Old 12-30-2008, 10:53 AM
whodat's Avatar
whodat whodat is offline
Bike year & model = 2005 de 200
Temperature (degF) =62-95
Elevation (feet) =1500-5000
Main jet = 172
Pilot jet =42
Needle & notch =LTR, middle notch
Air screw setting =2 out
Throttle valve/slide =# 7 with power-now(this cleaned up jetting from top to bottom)
Results:wide open jetting is easy, the transition from the basement to the mid was difficult. Technical terrian requires(from me, anyway) great jetting from idle to 1/4 throttle and the power now mod combined w/pilot and air screw being just right was critical. Poor idle was handled by cutting a little off a the spring on the idle adj screw. I know it is "primitive pete" but it works.
Old 04-01-2009, 02:35 AM
iancp5's Avatar
Temperature (degC) = 5 - 20
Main jet = 180
Pilot jet =45
Needle & notch = CCL #4
Air screw setting = 1.5 out
Throttle valve/slide = #6
Pobit recommendation and spot on. Smooth power and torque no holes no surprises. Very pleased much better than previous jetting which was the more common 200 setup in the UK.
Old 04-06-2009, 03:01 AM
gg3's Avatar
gg3 gg3 is offline
Bike year & model = 2002 EC 300
Temperature (degF) =12c-38c
Elevation (feet) =0-1000
Main jet = 180
Pilot jet =40
Needle & notch = N1EF 3rd clip
Was running a 38 pilot but had moments of it running 'surgy' when hot,idle would waver a bit.
Now pulls hard & consistent off the bottom,smooth strong mid & a 'holy shit batman' top end.
Old 04-06-2009, 05:35 AM
wence's Avatar
wence wence is offline
Bronze Level Site Supporter
Bike year & model = 07 EC 300
Temperature (deg) = 15-30
Elevation (feet) = 0-1000
Main jet = 180
Pilot jet = 42
Needle & notch = n1eg 2nd from top
Air screw setting = 1-2 turns out
Throttle valve/slide = #7
Results : Very smooth right through the rev range no bogging or flat spots.
Heaps of low to mid and mid to high range power( right through I guess).
Stock except for fmf powercore2 muffler.
The jetting database needs your help! MattR General Discussions & Announcements 4 10-18-2017 05:34 PM
JD Jetting settings for linear power delivery? SpeedyManiac Enduro Intake/Carburetion - 2 stroke 5 04-06-2010 06:17 PM
Modification/Aftermarket Database SpeedyManiac Enduro Product Reviews 4 02-04-2009 07:09 AM
Jetting Database Announcement MattR General Discussions & Announcements 0 12-18-2008 08:58 PM
Jetting Database Summary MattR Enduro Intake/Carburetion - 2 stroke 0 12-18-2008 08:36 PM
