Old 02-01-2019, 01:11 PM
GASGASCWB GASGASCWB is offline
Default Pro design super cooler!!!
Hi guys.
I bought the PRO DESIGN SUPER COOLER and now I need to install it on my GG EC300 2018.
https://www.prodesignracing.com/super_coolers.htm
I'm not sure which hose he goes in!
The explanatory leaflet reads as follows:
"SUPER COOLER must be installed in upper hot water line." Then cut water line 3-6 inches from return water spigot from head "Note: very important make sure you install in hot water return line."
Can anyone tell me with absolute certainty what this hose is?
Appreciate.
Old 02-01-2019, 03:01 PM
The hot water return line is on the left side.
You won't gain anything by adding the cooler.
Just creates another place for a coolant leak.
Old 02-01-2019, 03:28 PM
Ok!
Hose #13?
Thanks again.
Old 02-01-2019, 04:49 PM
The bottom left hose is the return.
Depending on the size of the fitting on the cooler, will determine which hose it goes on.
Usually, those coolers are used for replacing the thermostat housing.
Old 02-01-2019, 05:29 PM
Originally Posted by GASGASCWB View Post
Ok!
Hose #13?
Thanks again.
So Not 13.
It will look nice and shiny but it doesn't equate to surface area in cool breeze. If it did you'd run 4 of them and take those heavy fragile radiators off.
Old 02-02-2019, 06:05 AM
So Not 13.
Not hose #13?
What is correct then?
At no time does the product in question say that it will make the radiator work...
Just say helper the motorcycle cooling system!
I read some feedback from customers who bought and were very happy with the result.
Thank you for your opinion on whether or not the product works, but I just need to know if the correct hose is # 13!
Thanks.
Old 02-02-2019, 12:58 PM
13 is the coolest part having come from the radiator. I link you posted instructions says 'upper'.
It would probably do the least harm if you put it on the hose 16 opposite the thermostat.
Old 02-02-2019, 08:40 PM
Thanks (F5)!!!
Old 02-13-2019, 02:32 PM
Leo's Avatar
Leo Leo is offline
Nambotim models used to come with this in line coolers.
It goes near 16 on your diagram on both sides.
But this ones you got is really small GasGas ones was much bigger.
Had it on my GG and machined a pair for buddy
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 02-13-2019, 10:39 PM
For effective energy transfer to occur you need a large delta of temperature and lots of area. But it's so hard to get a fair comparative test and so easy to market machined bits.
Edit; just seen Leo pics. Yeah they have some area.
Be nice if weren't shielded by radiator mind.
450 Oil cooler? Dave99 Enduro Engine 4 stroke (including EFI & Exhaust) 1 09-16-2017 07:45 PM
In line cooler. Leo Enduro Chassis & Body 3 08-29-2012 09:26 AM
inline water cooler? nato Enduro Engine - 2 stroke 14 05-15-2012 06:23 PM
