Old 11-27-2010, 07:44 PM
AZRickD AZRickD is offline
Default 2011 300 SixDays Set Up Advice
My club mate got his first couple of rides on his 2011 SixDaze 300. Zokes front, Ohlins rear. The static and race sag appears to be in the ball park. He had to adjust the shock clickers to slow the damping down a bit. Other than that, he hasn't touched it.
He's 210 pounds without gear. A very fast 30A racer. We don't have much in the way of roots here. We have rocks, and more rocks and various types of sand wash.
What would you experienced suspension guys recommend for his sag and clicker settings? Are the stock springs good enough for his weight? Any revalving recommendations? How long for the new suspenders to break in?
Old 11-27-2010, 10:28 PM
GMP's Avatar
GMP GMP is offline
We never got an answer on the spring rates used in the new bikes. Valving is a guess as well. Assuming the fork valving is similar to the '07 - '08 Zokes, HS rebound will be too light. Clickers are of limited value in fixing this. The shock is also a guess but no stock GG I've ridden was bad in rocks, just had room for improvement. Just start with rebound about 10 - 12 out F&R, Comp a little looser, and avoid too much preload on the rear spring trying to make a sag number. Guys with the bikes will soon be able to tell us more than we know now. Good Luck!
Old 11-28-2010, 08:46 PM
matt_tidball matt_tidball is offline
I am the guy with the new 2011 300 Sixdays. I weigh 215, 235 with gear. After 2 days and 4.5 hours of time on the bike I have backed out compression on both front and rear to almost 0. The rebound is about a few clicks from in. I also had to take half a turn out of rear spring preload on the trail to calm down the rear end. The biggest differance came from from backing off the spring preload a bit. this also decreased the head jitters at high speeds. I found it strange for a person of my weight and riding level (A vet) to have to back off a stock bike so far. Who is this bike set for stock? I still have yet to use all the suspension in G outs or jumps. The suspension works well now everywhere now except in sharp hits and mid sized rolling rocks. I suspect it could use some shim stack work on the initial stroke to calm the sharp feel. I hope this helps out, and I would also appreciate any feed back.
Old 11-29-2010, 07:39 AM
GMP's Avatar
GMP GMP is offline
Matt,
Overall I would guess the thing is valved seriously stiff if a fast heavy A guy can't use all the travel, and again, '11 valving and especially on the SixDays is likely different from what we have seen before. Your preload observation is dead on, avoid more than 10mm on the shock spring, the sag #s on GGs tend to be on the higher side of what you think is normal. The forks biggest problem IMO is the lack of adequate HS rebound, making it feel like a compression problem. The '07 at least had a strange three stage comp stack that worked better than it should have. The fork is excellent when tweaked a bit. Talk to Les at LTR. Do you know what springs are in the bike?
Old 11-30-2010, 02:05 PM
Troy F collins's Avatar
Troy F collins Troy F collins is offline
Yes seems set up very stiff
My 2011 EC250 is actually pretty calm......uses all the stroke no prob....perfect at low speeds..roots,logs etc..this is the sachs's set up though..I'm 6'1 200lbs...maybe a bit loose at higher speeds...but I havent touched a clicker yet
I'd give it more break in in time with the clickers backed out....sound like the 6 days has a more aggressive set up ...?
Old 11-30-2010, 04:34 PM
GMP's Avatar
GMP GMP is offline
Seems so, but the knowledge base on the Zokes is quite developed and they are outstanding when tuned correctly.
Old 11-30-2010, 05:23 PM
widebear's Avatar
widebear widebear is offline
Banned
Turning the clickers full soft will only make the forks harsher. The compression clickers only work the low speed circuit, more turns out means more oil bypasses the shim stack and you blow through the low speed circuit into the mid. Whatever the stock spring rates are in there they are gonna be to soft!.46 fronts with 5 mm preload and 5.7 year is your target with 30 mm free sag rear. I dont care how fast your buddy says you are if you set up properly you'll be faster. If your not bottoming its a oil height thing.
Old 12-02-2010, 03:12 AM
moto9's Avatar
moto9 moto9 is offline
Stock Marz and Sachs valving is pretty far off IMHO, if you ride anything with roots, rocks, high speed bumps...the fork is way too harsh and no amount of clicker turning will fix that.
I have said this over and over again, the suspension needs re-valving and a proper spring rate for the rider.
The bike is night and day difference, I posted this in another thread that I recently road a friends 09 300 with stock suspension...I gave it back a few turns down the trail...it was horrible...I couldn't ride it.
My advice to anyone that wants a great handling, fun to ride, down right trail killer...forget the bling, spend the money and get the suspension fixed "properly fixed"
Old 12-02-2010, 10:34 AM
widebear's Avatar
Banned
I rode a 09 ec 250 with stock sachs and thought it was pretty darn good. In fact I would not revalve just springs and oil height.
Old 12-02-2010, 11:43 AM
moto9's Avatar
Well, you and I may ride very different terrain, or I may be spoiled with how well mine works in comparison.
But the fact is our two bikes work very differently, mine is plush and floats over the roots and my friends 09 hammered the hell out of me + some major deflecting on the same trail section.
EC300 SixDays 2011 Elvis74 General Discussions & Announcements 10 09-17-2010 06:05 PM
2011 GasGas Sixdays noobi General Discussions & Announcements 38 09-02-2010 06:06 PM
Advice, How much? W8TSON General Discussions & Announcements 7 12-21-2009 03:30 PM
Need advice please gascanuck General Discussions & Announcements 2 12-15-2009 07:26 PM
Advice Please sbute General Discussions & Announcements 3 11-11-2009 07:04 PM
