Old 04-06-2017, 03:16 PM
flam66 flam66 is offline
Default Still no start
Thanks for your help so far guys,
I must admit it does seem like cam timing,
Tooth 7 lines up with sensor, should I line the front of the tooth with the centre of the sensor to be precise?
Does this look correct I make it 14.5 pins between marks,
Lobes pointing 10 and 2 o'clock,
Could the chain be stretched? It has a manual tensioner with about 10mm of travel left.
The spark plug only looks wet when starting with wide open throttle?
Cranking voltage 11 volts
Cranking about 300 rpm according to guzzidiag
All parameters reading, all seems correct compared to 1 on the forum.
Cleaned every connector today in the loom,
Will go and check Ecu pins.
Is it possible for the cam chain gear on the crank to slip?
Thanks again
Old 04-07-2017, 12:46 AM
Tafka Tafka is offline
I've usually aligned center of the tooth with center of pickup coil. But center and front of the tooth is so minimal change so i don't believe that could change anything.
Timing on your cams seems ok to me...
Have you tried new spark plug?
Throwing out ideas....
Usually when my FSE wount start normally then it will start with wide open throttle. BUt yeah try maybe new spark plug? :/
Old 04-07-2017, 02:55 AM
Yngvim Yngvim is offline
Check through the spark plug hole if the piston is in tdc
EC 250 2001, FSE 450 2004
Old 04-08-2017, 01:41 PM
Default It's alive
She's up and running!!! never would of found it without guzzidiag, ignition tested fine when plug wasn't in the head, but when I screwed it in the head with the coil pack on it threw up a fault, after alot of head scratching I found the steel outer tube on the coil pack had slipped down, pushed it back up siliconed in place, jobs a goodun, cheers
Thread Tools
Display Modes
2004 fse450 backfires and wont start jethro Enduro Electrical & Wiring 5 06-02-2015 01:22 PM
2004 gas gas 450 miah Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-12-2015 09:40 PM
2004 fse sm 450 Horsepower Enduro Engine 4 stroke (including EFI & Exhaust) 0 05-25-2011 02:25 PM
