Old 08-21-2017, 12:14 PM
jeremy358 jeremy358 is offline
Default 2011 ec300 rectifier
Hello. I had two out of the four wires pull out of the plastic 4 pin connector that plugs into the rectifier. I don't want to mix them up and chance shorting the cdi. Can anyone tell me the order of the wires?! Thank you!! 2011 ec300
Right now I have -red wire/black stripe (on the one end)
-next is white wire
-yellow wire/green stripe. (Pulled out of connector)
-yellow wire. (Pulled out of connector)
Thanks!!!
Old 08-21-2017, 02:56 PM
Neil E. Neil E. is offline
I can pull my sidecover and have a look, just not right away. How quickly do you need to know?
2011 EC250E
Old 08-21-2017, 07:41 PM
Red/black
White
Yellow/Green
Yellow
Note their position relative to the latch and you should have no trouble (just in case your rectifier is turned around or on a different angle).
2011 EC250E
Old 08-22-2017, 12:57 AM
Perfect! Thanks so much!
Rectifier for horn? k1322 Enduro Electrical & Wiring 1 11-02-2014 03:23 PM
2013 EC300 E - GasGas Fan Rectifier/Regulator FDB Enduro Electrical & Wiring 2 10-25-2014 02:10 PM
do i need a rectifier? hotrod Enduro Electrical & Wiring 1 07-25-2012 05:16 PM
Regulator/Rectifier Needed hudson_hollow Other GasGas Bikes/Quads 3 05-27-2008 10:33 PM
