Old 11-24-2017, 01:59 PM
BLD's Avatar
BLD BLD is offline
Default How do I remove the ignition sprocket?
Help! I’m repairing the e-start on my ‘13 XC300 and can’t figure out how to remove the ignition sprocket. I see threads inside the large nut holding the sprocket on. Do I need a special tool that threads in there, or does anyone have any other tricks to keep the unit still so I can remove the large nut on the sprocket?
I figured the Honda bendix swap would be the more difficult part...
Thanks!
File Type: jpg E014A961-2127-4D2B-9A6A-372F381207E7.jpg (128.3 KB, 38 views)
Old 11-24-2017, 03:43 PM
hamilton's Avatar
hamilton hamilton is offline
You just need to remove the large nut. 1/2 impact gun is the easy way.
When you install it and torque to spec just put the engine in gear and use something like an old screwdriver handle between the rear sprocket teeth and chain to keep the wheel from spinning.
15 GASGAS EC 250
19 Sherco SE 125R
Old 11-24-2017, 04:08 PM
BLD's Avatar
BLD BLD is offline
Really? I have an air impact wrench. I figured that would just turn the motor...
I’ll have to grab a 31mm socket for it and give it a shot.
Update: Thanks Hamilton, that was the ticket! No 31mm sockets available, but a 1 1/4” socket and my air gun got it done. I have electric start now!!!
Old 11-26-2017, 05:51 AM
Leo's Avatar
Leo Leo is offline
Using a impact gun to remove this nut get me thinking about how conecting rod bearings handle this impcts....
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 11-26-2017, 10:22 AM
After you remove the nut you will need a flywheel puller. Do not pry on the flywheel as it can damage the bearings or flywheel.
Old 11-29-2017, 02:03 PM
BLD's Avatar
BLD BLD is offline
Leo, I wondered about that. Turns out my impact vibrated the gear less than the bars do when I?m riding so I?m not too concerned. Hopefully there will be no reason to pull that gear again for a long while...
Thanks Zman. Thankfully I didn?t have to pull the flywheel. I was just replacing the ignition sprocket because the PO ground some teeth off. New Honda Bendix parts and a new ignition sprocket and she?ll start cold with the first push of the button.
I do have to laugh at the starting instructions in the manual. It seems like even GasGas knew the e-start was a dud from the gate. Look at the attached image below, it looks like the e-start instructions still tell you to use the kick starter vigorously!
File Type: jpg 70ACD760-FB04-4420-B1F0-E0CA91896583.jpg (8.2 KB, 11 views)
Ignition sprocket pigpen966 "Wanted to Buy" & "Want To Trade" 4 10-25-2017 05:09 PM
Flywheel Ignition sprocket wanted nestz Parts 6 11-19-2016 11:36 AM
How to remove Flywheel? Fabry Enduro Engine - 2 stroke 12 08-16-2013 03:27 PM
how do you remove the kickstart noobi Enduro Chassis & Body 13 09-22-2011 03:31 PM
04 300EC Ignition changed to DE Ignition Trail Blazer Enduro Engine - 2 stroke 0 01-08-2007 01:48 AM
