Old 03-16-2014, 05:03 AM
Default EC300 Supermoto conversion
Hopefully the gods of eBay will grant me a set of wheels, discs, tyres, spindles and spacers from a very common 17"er today (if not, another day very soon!!), in which this post will be my 'diary' for the process.
Stay tuned!
2016 RM-Z450
Old 03-17-2014, 09:38 AM
jt633 jt633 is offline
What is the benefit of the rm125 cdi?
2004 ec 300
Old 03-17-2014, 12:29 PM
The benefit is that the EC300 CDI stopped working , though 125's generally rev higher and are timed to suit, so my bike may have super powers, won't know until I dyno it one day .
Anywho, I lost bidding on the wheels, so I bought another set of the same ones .
GS500
First hurdles will be the discs
Front disc -
EC300 - 260mm
GS500 - 310mm
Rear disc -
EC300 - 220mm
GS500 - 250mm
I'll start with the rear, in which I will either turn down the OD and see if there is enough meat left for braking, if not buy this cheeky little rascal
http://www.ebay.co.uk/itm/2311266968...%3AMEBIDX%3AIT
and turn out the center clearance!
2016 RM-Z450
Old 03-17-2014, 12:57 PM
http://www.bikebearingshop.co.uk/C8.htm useful bearing sizes
2016 RM-Z450
Old 03-17-2014, 02:46 PM
Bearings required (to fit 20mm axles)
Front wheel, 2x 20x42x13 (60042RS), (this is supposed to be 20x42x14, but good luck finding that bearing, the centre spacer will be the same length, just the outer spacers +1mm).
Rear wheel 2x 20x47x14 (60042RS)
Cush drive 1x 25x62x17 (I'll keep this the same and make the spacer to fit)
2016 RM-Z450
Old 03-20-2014, 11:10 AM
WAZ WAZ is offline
I've just done a similar conversion to my EC300, but with Aprilia RS125 wheels. I originally started off with Bandit 400 wheels but they were just too much work to fit. If I can work out how to post pics, there should be a photo of mine below!
Old 05-24-2014, 10:40 AM
Anders Anders is offline
My son Fredrik's 08 Ec300 Racing with 2010 (?) black plastic and stickers. He bought some seconhand 17" wheels locally. Luckily, they appear to be OEM GG wheels so the conversion was pretty straight forward. He uses BT090 tires.
The fron brake setup is a 320mm brake disk, 6-pot ISR caliper and Brembo radial master cylinder.
Sent fra min GT-I9505 via Tapatalk
2002 450 FSE Supermoto conversion wakeymatt Pictures & Videos 0 08-05-2012 12:04 PM
Supermoto Conversion EC250 Ryan_250 Enduro Chassis & Body 6 05-16-2012 10:02 AM
Gas Gas EC300 2001 Supermoto maybe johns2394 Enduro Chassis & Body 12 01-29-2009 07:58 AM
2005 FSE 450 Supermoto Conversion reidnv Enduro Chassis & Body 7 01-01-2009 12:51 PM
