2018 GasGas XC300 Flywheel Weight
Id like to run a heavier Fly wheel on my 2018 XC 300... I have searched and searched and not found anyone making one yet. Has anyone had any luck with sourcing a flywheel for a 2018 model?
For non electric starter models it is simple. Have machined one for my 2011:
https://youtu.be/16d-ewfc8lU For electric starter models, there a gear attached where flyweel weight should be. The solution I see is make another heavier gear.
www.endurohp.eng.br Sherco ST300 2015 (Trials) https://www.instagram.com/leocm74/ Brasil! |
EC flywheel is heavier
I dont think it is? I havent seen any official material that says the XC has a lighter FW.
The 2018 EC and XC use the same flywheel from what I can find. They do both have the same part numbers so I think that is the case.
From what I can see, the only differences are the lights and expansion chamber. I'd like to make this easy by purchasing a part and slapping it in before I commit to the down time of making something custom... but if I don't find an option in the next couple weeks I'll be tearing it down and figuring out a solution. |
Adjust the power valve , see if it helps.
Picked up a 2018 XC300! | Adrian200xc | General Discussions & Announcements | 8 | 11-06-2017 09:09 PM |
S3 Flywheel weight? | motopsycho87 | Enduro Engine - 2 stroke | 6 | 04-14-2014 11:10 AM |
GasGas FlyWheel weight (homemade) | Leo | Enduro Engine - 2 stroke | 7 | 01-03-2014 06:24 PM |
12 XC300 where is the weight? | Bandit9 | General Discussions & Announcements | 18 | 10-16-2013 07:33 PM |
flywheel weight ? | GAKLX | Enduro Engine - 2 stroke | 17 | 11-10-2008 09:01 AM |
