Old 12-03-2021, 11:38 AM
JAD JAD is offline
Default Fast idle.. Confused! / Ec250 2007 with keihin pwk.
I have set up the carb as per advice on here and it runs well in every way except this annoying high idle issue.
When started from cold with choke the idle is very high so I push the choke knob in straight away. It then has a fast idle... Not ridiculous just a high idle.
If I select first gear and engage the clutch a bit the idle reduces and stays just right.. even back in neutral.
If I blip the throttle it regains the high idle...?
I can reduce the idle to normal using a touch of clutch (in gear) every time.
It starts and runs lovely otherwise.
Any thoughts on why this happens?
Thanks
Sent from my LLD-L31 using Tapatalk
Retired
EC 250 (2007)
UK
Old 12-05-2021, 12:04 PM
JAD JAD is offline
Note.. Bought a new carb from China and now all is well...
Retired
EC 250 (2007)
UK
Super fast idle after removing cable choke Wypipo Enduro Intake/Carburetion - 2 stroke 14 10-07-2018 07:45 AM
Sticky idle EC250 mrfreezer Enduro Engine - 2 stroke 3 08-08-2018 01:03 PM
pipe armor for EC250 2011? :confused: a c t i v e X Enduro Chassis & Body 23 01-03-2012 03:14 PM
06 ec250 knock (off idle) fullthrottle Enduro Intake/Carburetion - 2 stroke 4 02-24-2008 07:57 PM
