Old 05-29-2017, 02:11 AM
Rampart Rampart is offline
Default FAN KIT FOR EC300 question
Hi all
Wanting to install fan on my gg. But it's not original kit. So i wondering what "voltage rectificator from AC to DC" is for, and can i install fan without it?
Old 05-29-2017, 02:16 AM
Anders Anders is offline
The fan is then most likely a DC fan. What model of bike do you have? Only the last models have DC system. If you have any older bike you must install the rectifier since it has an AC system..
Sent fra min E5603 via Tapatalk
Old 05-29-2017, 05:12 AM
the fan is the one that comes on the GG trials bikes.
https://www.greenlandmx.com/en/p/oem...ifier-txt/7008
I have one on mine, but since it does not have the battery i have the rectifier. I will find out what information is posted on the unit later today.
Old 05-29-2017, 07:14 AM
I have ec300 2011
Old 05-29-2017, 08:23 AM
with or without e-start is the actual question i think.
sorry nothing marked on my rectifier, may have worn off
Old 05-29-2017, 10:14 AM
http://www.motocrosscenter.com/shop/...c-dc-3251.html
Old 05-29-2017, 11:00 AM
Neil E. Neil E. is offline
That rectifier should be an easy install. The black and red are your DC output to the fan. The yellow and white wires are for AC. You need to locate the yellow wire that comes out of your stator and connect into that circuit with the yellow wire on your rectifier. The white wire on the rectifier is then grounded to complete the circuit. The fan will run whenever the engine runs.
In the kit there is a thermoswitch you can add to the circuit. Put it in series with the white wire. This will let the thermoswitch ground the rectifier to create your DC for the fan. This is the way the kit is intended to be used so the fan engages only when the coolant reaches the temperature limit.
On the AC input it does not matter if you hook up the wires opposite (connect the white and ground the yellow).
Old 05-29-2017, 01:20 PM
Thanks all, but i don't understand - should i install rectifier with fan, or i can install it without rectifier?
Old 05-29-2017, 04:04 PM
You should use the rectifier.
Old 08-10-2019, 11:11 AM
Moto7man Moto7man is offline
Default Add Fan Question
This is kind of a dumb question but I want to to mount a fan on my 84 RM 250. I am going to use a Spal Fan with a switch. This is the stator before restoration. My stator only has the two AC wires. Do I need a new stator with dedicated power source wires? Like in the video below,
URL="https://youtu.be/zEQu-JMfUSg"]https://youtu.be/zEQu-JMfUSg[/URL]
―Comedian Lewis Black
-Unknown Sardaukar
12 EC300 mapping question knocklife Enduro Electrical & Wiring 1 09-24-2014 12:45 AM
06 EC300 Question ECTim Enduro Electrical & Wiring 5 08-27-2014 04:29 PM
Starter question 2011 EC300 iamovru Enduro Electrical & Wiring 3 02-17-2014 12:01 PM
Gas Gas ec300 plastics question. Tricky Enduro Chassis & Body 4 01-07-2014 10:55 AM
EC300 Dim Electrics Question rogerc Enduro Electrical & Wiring 2 03-02-2009 11:47 AM
