Old 05-20-2008, 09:03 AM
captainslow captainslow is offline
Default 400 fse cam/valve clearances
Hi
Ive just measured the valve clearances on my bike and they are bigger than what the manual says, my mate says that if the gaps are bigger then its ok and that it's when they are smaller that u need to do something about them is this true?
bit of xtra info:
the manual says inlet 0.15mm and exhaust 0.25mm clearance.
my bike measures inlet 0.20mm and exhaust 0.30mm
i'm just a bit concerned 'cos if the worst happens i wo'nt be able to afford a top end rebuild.
Thanks for ne advice
Old 05-22-2008, 07:28 PM
INABIL INABIL is offline
Is it hard to start the bike?
Bill
'03 EC400fse
'95 KX 250
Old 05-23-2008, 03:01 AM
Sandman Sandman is offline
You should try and keep the clearance to 0.15 in and 0.25 ex.
With the de-comp it is cridical to have the exhaust clearance correct.
On the early 400/450 they had some cam problems so check the shim
buckets and cams are not worn.
Old 05-26-2008, 09:24 AM
Bike starts fine, tho it can be a pain when its freezing.
'07 GasGas EC200
'03 GasGas 400FSE (sold)
Old 05-26-2008, 05:19 PM
I check my valve clearance when it gets hard to start when warm.
When cold my bike doesn't start instantly like when warm probably cause of air pocket in fuel line? My tank seems to be putting pressure on the fuel line which sits on part of the frame, it came apart one time on me and started squirting fuel on my leg when it came apart at the clamp. (need to re route it)
I try to keep a full charge on my battery with a battery tender.
Bill
'03 EC400fse
'95 KX 250
to valve or not to valve.... that is the dilema. dank Enduro Suspension 19 05-06-2010 07:41 PM
Top End Clearances/Specs SpeedyManiac Enduro Engine - 2 stroke 4 09-24-2009 09:53 PM
fse 400 valve timing ??????? mcludd Enduro Engine 4 stroke (including EFI & Exhaust) 4 08-29-2009 11:54 AM
pwr valve knock dustbuster Enduro Engine - 2 stroke 10 08-06-2007 01:36 AM
Valve Help bxb Enduro Engine 4 stroke (including EFI & Exhaust) 2 03-06-2007 05:31 AM
