Old 06-17-2011, 12:11 PM
dickieshep dickieshep is offline
Default Rich or Lean
I am new to 2 strokes and have an EC300 that is running rough.
In first gear on a barely open throttle it feels like it is stuttering and continues this way upto about half throttle.
Can someone please tell me what it would feel like if it was running lean and running rich.
Thanks.
Old 06-17-2011, 01:45 PM
Thanks.
It would help to know what your current settings. The main controls 1/2 to full throttle so what you need to know is pilot size and how many turns out on the air screw as well as which needle and which notch the clip is in the needle.
You could start by turning the air screw one way or the other and see if it gets better or worse.
Old 06-17-2011, 02:45 PM
If it is the Air Striker II, it would be rich.
The AS II likes to be jetted lean, the needle also plays a major part in the jetting now.
Old 06-17-2011, 06:35 PM
Second that its most likely rich.. Pull the choke on and see if it gets worse to confirm.
A rich condition will burble ba baba baba ba kind of like and won't want to rev.
A lean condition goes flat for a moment and then twangs with a surge of power. Booo waahh! sound.
Now close your eyes and imagine me making those sounds
Old 06-17-2011, 06:57 PM
nambo-trev's Avatar
nambo-trev nambo-trev is offline
how does that sound go again?????lol
trevor
Old 06-17-2011, 08:02 PM
mrkartoom's Avatar
mrkartoom mrkartoom is offline
I agree it is very likely too rich. Anytime you get sputtering and not revving cleanly you're usually rich. I also describe it as "breaking up", like running with the choke on. Do what Jakobi says and pull the choke on when running. I'll bet it gets even worse.
2011 Gas Gas EC300 38mm, 2008 Husky TE610, 2003 Beta Rev3 250
Old 06-18-2011, 02:38 AM
Thanks for the replies.
Choke out makes no difference, so how do I lean it up a bit
Old 06-18-2011, 04:45 AM
wasp4banger wasp4banger is offline
I'd try dropping the needle by one clip position to see if this helps
Gas Gas EC 300 '06
BMW F650
Old 06-18-2011, 05:36 AM
Cheers for that.
Old 06-18-2011, 05:45 AM
Suprisingly that really helped! think mine is running rich.
Check-out these RICH Settings GasMCAndy Enduro Intake/Carburetion - 2 stroke 3 05-01-2011 11:45 AM
250MC has gone LEAN! GasMCAndy Enduro Intake/Carburetion - 2 stroke 5 01-30-2011 12:37 PM
Running rich Evans P Enduro Intake/Carburetion - 2 stroke 2 02-26-2010 12:50 PM
Running rich rustygun Enduro Engine - 2 stroke 4 06-20-2008 04:18 PM
