Old 12-20-2012, 04:36 PM
hillbilly's Avatar
hillbilly hillbilly is offline
Default ec300 06 front sprocket loose on countershaft splines
Anyone had problems with excessive wear of splines on countershaft where sprocket fits. Just rebuilt engine, (failed main bearings) and when fitting new sprocket noticed there seems to be a lot of slack between two components. Dont really want to tear down engine again to fit new shaft. Had an 03 450 a couple of years back and that had same issue, might expect it for older bike but this 06 not done much work. Laid up 2 years and trail ridiing only befoe I go it. Any ideas? Maybe thats how they are? Tried 2 new sprockets and both same, visually splines don't look worn either.
Any info appreciated
Old 12-20-2012, 07:37 PM
Rick's Avatar
Rick Rick is offline
Do a search....this is not the first time this subject has come up.
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
***Thanks for the support : Twin Air /O'Neil Racing / Race 100% / Matrix Concepts / ODI / Mika Metals
Old 12-21-2012, 12:18 AM
jostby jostby is offline
hillbilly, maybe this will help as it's all I found of your description by doing a search for "sprocket"
http://www.gasgasrider.org/forum/sho...light=sprocket
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 12-21-2012, 07:31 AM
eff's Avatar
eff eff is offline
What kind of sprocket is it? I had that issue with the Ironman and won't use them. I also found that the Renthal and Talon fit much better and wear just as long.
2004 GasGas DE250
Old 12-21-2012, 11:36 AM
Rick's Avatar
Jostby,
No worries, I was not trying to be a short with hillbilly, it's just that so many questions come up that have been already been discussed in other threads. If a member or new members were to perform a search on the question they could very well find information and answers to other questions as well.
Thanks
Rick
99 EC 200
06 RM 250
AMA D36
375X
OTHG
375S
Old 12-21-2012, 05:17 PM
hillbilly's Avatar
gents
thanks for the input from all.
Had actually searched subject and seen that a few others had same issue and I have come to conclusion that for time being trying locitite fix some have done may keep me going until I can face stripping down to replace shaft.
I was more interested in the reason than the fix in a way.
Been riding 30 years and never had this with any other bike and last 2 gassers had same problem! Well aware of chain tension issues and grit in splines being possible causes etc but dont think I'm that bad at looking after my bike.
Just made me doubt the quality of shafts hence asking to get an idea of how much of a common problem it is. Love gassers to ride but dubious quality in some areas makes you question eveything.
Buy some 271 and 638 loctite when I get home from offshore, (yes away for Christmas so not happy) and try that. Have my doubts it will hold for long with the constant snatching from drive.
Old 12-21-2012, 05:22 PM
hillbilly's Avatar
eff
Not sure what was on there when I bought bike but had Talon on for last year or so. Very little use, maybe once a month and mostly trails. swap between 14T and 13 T depending on amount of road work I am doing and how tight the riding off road.
Assume you fitted new shaft at some point after wear issues? Presume you've had no problems since? Wonder if quality control on shaft dimmensions a bit shaky in the past and certain bikes landed up with out of tolerance shafts which would lead to premature wear or just slack as old boots from day one.
Old 12-21-2012, 09:50 PM
GMP's Avatar
GMP GMP is offline
Ironman, while a very durable sprocket, fits somewhat sloppy. It also needs shimming. My '07 is like this too but the splines are OK. The Talon on my '12 is trash already after 50 hrs. I'm just going to use another Talon or Sprocket Specialists, have never tried their countershaft sprocket.
Old 12-22-2012, 08:01 AM
twowheels's Avatar
I'm OK with 50 hours out of a front sprocket. Given what you ride out east it's one of the hardest working parts of the bike.
PlusOnePerformance
Steven Beane #275
afterhourscycle.com
Old 12-24-2012, 08:29 AM
eff's Avatar
eff eff is offline
Originally Posted by hillbilly View Post
eff
No spline shaft issues, just stopped using ironman sprockets and the the issue was solved.
2004 GasGas DE250
countershaft sprocket bones150 General Discussions & Announcements 9 05-30-2012 11:22 AM
Countershaft sprocket seal assembly 3hunerd Enduro Engine - 2 stroke 5 04-01-2012 08:21 AM
Countershaft sprocket shim 3hunerd Enduro Engine - 2 stroke 5 03-24-2012 09:29 AM
Front sprocket? wence Enduro Chassis & Body 8 09-18-2010 02:12 AM
FSE 450 W/ 14t Front sprocket??? cal_tony Enduro Chassis & Body 5 12-09-2008 09:47 AM
