Enduro Product Reviews Feedback & Comments on Products Tested |
#21
+1 on the ultra heavy duty tubes. Man, those things are about 3mm thick! I rode all last season with no issues and I'm not planning to replace them any time soon (may yet regret that decision). I guess it really does depend on your terrain, and pace.
Barry 07 EC250 |
#22
I think it also depends on your style, some guys just ride over everything, some pick smoother lines. I have a friend like this, gets constant front flats, but he rides like he's driving a bulldozer. There are more rocks than dirt on my trails and I have only slashed a sidewall once, on a Michelin X-11 trials which is a very weak tire. Try a Tubliss at less than 10 PSI, you do not feel the rim like you think you would and traction is great. Very confidence inspiring.
#23
I've been racing the past 5 months with the Tubliss system. I've gotten one front flat tire, but it didn't affect my result much. I rode 40+ km on it with no issues. The tubliss system isn't as robust as bibs, but it does last longer (after a season bibs are toast) and is better for regular riding, IMHO. Changing a bib is dead easy and only takes 5 minutes so I won't get into that debate.
#24
just changed a rear with slime in a tubliss system. it is not messy like i thought.. there was very little slime on the tubliss system, it was all stuck to the inside of the old tire. works great.
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com |
#25
Makes sense, cent force slings all the slime to the outside away from the insert.
Next time I'm going to use slime on the bead as a sealing aid. That should eliminate some of those slow initial leaks. Maybe make use of previously mounted tires doable too. |
#26
I have used slime/tubliss successfully on old tires and as it is not a difficult job changing tires with tubliss it makes the old tires more attractive, especially if you have a knobbyknife
#27
I am just about to throw in the towel on Tubliss. I have had many flats and recently, a high speed crash as a result of sidewall nicks/slashes. We have a lot of sharp rocks where we race and my confidence is shaken.
I'd like to move to mousses, but can't get the damn rear on. Front was a snap. Maybe till I can get some advice on how to get the rear on, I'll run a mousse front and a TUbliss rear. At least if I flat the rear, it's not an instant loss of steering/crash scenario. 5th gear wide highside changes the way you feel about predicatblilty/reliabilty. Mousses are looking real good despite any "pain" involved in install. If the pros can do it in 2 minutes, it's just another skill to be learned..... |
#28
have you seen the new mousse 'sections' for lack of a better term? my local shop has some - they are kinda like mousse meets tireballs. seems like they'd be easier to install and pressure can be regulated.
#29
It will be interesting to hear if you can feel a difference in handling once you switch to mousses
#30
http://www.flattiredefender.com/moto...uctfitment.htm
Tubliss with dinged rim | GMP | Enduro Chassis & Body | 2 | 09-06-2010 05:29 PM |
Tubliss Questions | GMP | Enduro Chassis & Body | 11 | 06-23-2010 07:20 PM |
TuBliss | roostafish | General Discussions & Announcements | 30 | 04-14-2010 12:15 AM |
Tubliss | ejas66 | General Discussions & Announcements | 14 | 12-26-2008 06:59 PM |
Trials Tire + Tubliss? | MIKEWA | Enduro Chassis & Body | 7 | 03-18-2008 06:03 AM |
