Enduro Engine 4 stroke (including EFI & Exhaust) 4 stroke engine, EFI, and exhaust discussion |
#11
Only the old units need a serial and a parallel port. The parallel port is for the dongle based "sentinel" software protection. All the later versions are usb based.
06 Gas Gas FSE 450 USA 07 Gas Gas FSR 450 UK with motard and dirt wheels |
#12
I just did the Technoreasearch VDST purchase. They were very good on the front end of my purchase, service & shipping, and said to call with any install or operational questions. Unit was here in three days, MI to CT. Did the software install last night on the laptop. Ran out of time to hook up the bike. That's on for tonight...
#13
My bike (06 450) was running erratically recently. All I did was take off each efi sensor, clean them with contact cleaner and then use dielectric grease when I put them back together. Worked a treat and took less than 30 mins and cost less than $5. Worth a try.
#14
Figured out the problem (A MUST READ)
OK........got the tecno research program installed on my lap-top, and everything checked out OK. No bad sensors etc., even the injector checked out OK. So then I was really scratching my head Decided to take the injector off the bike and found black crap in the inlet end of the injector!........IT WAS PARTIALLY PLUGGED!!!!! Even though it checked OK (which it was), it wasn't able to do its job and inject enough fuel as it was blocked. The culprit? Only explanation is the Ethanol fuel was eating my fuel line even though I put the StarTron additive in it prior to staorage! Put the bike back together and it runs perfect! IF YOU OWN A 4T BIKE, DO NOT RUN ANYTHING OTHER THAN NON ETHANOL FUEL IN IT........OR IF YOU DO, DON'T STORE THE BIKE WITH THAT S--T IN IT! That stuff is bad news! I missed a whole summers worth of riding because of it! The moral to the story? If your fuel injected 4T bike feels like it's starving for fuel, check the injector.
#15
Fred Overstreet 2010 EC250 SixDays 2004 GasGas EC300 -Sold to a good home 2006 GasGas EC250-Sold to a good home 2006 GasGas TXT 280 Pro |
#16
Unfortunately the GG works in open loop mode and therefore has no exhaust sensor which would have thrown a code. Looks like it will have to be added to the maintenance schedule!
450fsr runs like crap, need help | fastisbetter | Enduro Engine 4 stroke (including EFI & Exhaust) | 2 | 05-02-2010 10:50 AM |
Running hot | Brian VT | Enduro Engine - 2 stroke | 9 | 10-01-2008 07:25 AM |
02 400 fse running prob | dan j | Enduro Engine 4 stroke (including EFI & Exhaust) | 3 | 08-14-2008 05:44 AM |
Crap Web site.. | TooFastTim | General Discussions & Announcements | 2 | 12-04-2007 02:13 AM |
Running In | Dingo | Enduro Engine - 2 stroke | 3 | 07-26-2007 11:36 PM |
