Old 05-04-2018, 07:32 AM
gasman88 gasman88 is offline
Default Gotta make due with what you got... Maybe?
I've been wanting a headlight. Just a headlight, nothing else. Right now I got number plate. I went to my old junk pile and took a front light off my old 84 it200 Yamaha. I have no idea how to wire it and I have no diagrams. He's some pictures. Any commentary or help would be great. Needs a nice coat of black spray, bulb is good. I believe the high low switch is still on the 200. I got multiple toggles if need be. My ec250 I don't think ever had a battery. There's no room for one. So could I run it off the stator? I got the 2.2k. exits at 10 o'clock, smaller flywheel. Or the little black box coming off the coil. Believe it's the reticifier? Anyonewould be great. Electrical is not my strong suit... At all.....
Old 05-04-2018, 07:48 AM
Dave Dave is offline
This diagram may be of help; the alternator is a 2K-3. The AC output is the yellow lead that runs to a voltage regulator. You will need a regulator.
diagram: http://www.gasgasrider.org/gg-wiring.jpg
regulator: https://www.rockymountainatvmc.com/p...tage-Regulator
'15 YAMAHA WR250F, '75 YAMAHA TY80 Gone: '00 380 EXC, '03 EC300, '07 YZ250, '07 250 XC-W, '08 YZ450F, '12 CRF250R
Old 05-04-2018, 09:21 AM
Ahhhh ok I got you. Thanks a lot.
Old 05-04-2018, 10:49 AM
Neil E. Neil E. is offline
A really basic setup would be to have it on all the time the engine is running. Yellow wire off the stator connects to voltage regulator lead and whichever HI or LO filament you want to use. Other side of filament connects to ground. Done.
Or you could connect the filaments using a single pole double throw toggle switch. Yellow to the common switch terminal, other switch terminals go to the HI and LO filaments. The common side of both filaments is then grounded.
Old 05-09-2018, 07:47 AM
So I will need a switch? I'll see how the it200 one is today. I got some videos last night using a test light. Yellow is indeed power. Here's a video. I don't have any switch hooked up yet. https://photos.app.goo.gl/LbefWxWbMAMjxysM7... I want to know what that wire Down near the expansion chamber is for. High/low switch? I just mocked up the airfilter so I could run some tests. This is a 2007 subframe on an 2005. I am waiting on my 07-09 plastics and airbox assembly.
Old 05-09-2018, 11:07 AM
You only need a switch if you want ON/OFF (basic SPST switch) using one headlight filament. If you want to change from LO to HI buy a SPDT switch (yellow connected to the common terminal). You could also buy a SPDT switch with a "center off" function if you want to turn the light off.
SPST=single pole single throw
SPDT=single pole double throw
center off means the switch has three positions
Your link does not work (just goes to some login). Attach the picture to your post if you want people to see it.
Old 05-09-2018, 11:23 AM
I'll have to take a picture. That was supposed to be a video. It runs up the left hand side of the frame. I'll snap a picture when I go up there. It connects to another wire that keeps going up to the handlebar area but someone cut it. It's powered so it had to go to something. I noticed it sparking like crazy when I started the bike. My guess is thhe switch.
Old 05-09-2018, 12:55 PM
This. 1 yellow and 1 white leading into 2 black. Maybe for original speedo?
Old 05-09-2018, 05:27 PM
I personally wouldnt be destroying that IT200 headlight surround as they are getting rare these days. Pretty sure I have a Honda one here I could swap depending on where you are.
Not a Gasser, but you gotta see...... desertgasser300 Pictures & Videos 3 12-27-2011 05:42 AM
The Pro's Make It Look So Easy Rick Pictures & Videos 1 12-04-2011 10:49 PM
Gotta Love It Rick Pictures & Videos 1 05-04-2010 05:59 AM
Do they make FMF SST gasser250sm Enduro Engine - 2 stroke 1 12-26-2008 10:16 AM
If we make it... would you buy it? Steve@Motowest GasGas Member Polls 12 07-09-2008 01:15 AM
