Old 02-05-2020, 02:38 PM
Westy Westy is offline
Default Ranger Ec300 Jetting
Hi all, newbie here, just bought a 2019 Ranger, fantastic bike but,
Id like some info on jetting?
Bike is standard, after running in for 400miles.
Main jet 160
Pilot 35
As 1.0
PWK 36 CARB
Needle has been changed to a NEDW, clip 2.
Much better idle to 1/4 throttle opening but it seems to lack a bit up top compared to the stock N1EF needle which was also on clip 2.
The stock needle was really spluttering at small/ part throttle, not smooth at all like my old 4 stroke 250.
Tried a 165 main tonight, and it was missing at wot?
Photo is from a ride on Sunday covering 50 miles of trials and lanes, with new NGK plug, last photo is from stock set-up with a Nippon plug.
I also have an NEDG needle to try?
Any ideas where to start guys? TIA
Sea level, North Devon UK.
Cheers Mark
Old 08-19-2020, 10:27 AM
Stewee64 Stewee64 is offline
Default EC Ranger Jetting
Hi Mark,
Did you get an answer for your jetting question?
I have an EC Ranger and was advised by the UK importer to set my carb up as follows:
Main: 160
Pilot: 35
Slide 7
Needle:NOZE
Clip: middle
I am about to try this combo (change needle) this weekend, so if you are interested i can let you know how it feels.
Old 10-16-2020, 06:15 AM
JohnTheBraptist JohnTheBraptist is offline
I ended up with:
NEDJ (Clip 3)
160 main
42 PJ
Old 10-17-2020, 06:42 AM
Originally Posted by JohnTheBraptist View Post
I ended up with:
NEDJ (Clip 3)
160 main
42 PJ
I reckon you will be able to go a lot leaner and cleaner than a 42 pilot, most 300s with the bigger 38 don?t need that big. I just jetted a 300 with a 36mm and it is running a 35 pilot with a NECJ needle. Just an FYI.
Old 10-20-2020, 09:49 AM
I just jetted the pilot for best throttle response. If i go any leaner with the air screw i get a bog...
She run well at light throttle with almost no four stroking
Old 01-10-2021, 01:51 PM
Update, after months of messing around i arrived at NEDH, clip 2, genuine 155 MJ, and a non genuine 42 PJ.
Have just bought a genuine 42 and 40 PJ, and a 158MJ, but due to lock down I can't test them.
Pulls clean all the way through In 6th gear no problem.
Slight burble at 1/8th throttle.
Cheers Mark
2011 vs Ranger singletracker General Discussions & Announcements 27 09-18-2023 01:14 PM
GasGas EC Ranger... Davehuge General Discussions & Announcements 32 01-03-2020 02:41 AM
GasGas Race Ranger 300 model is here Keg General Discussions & Announcements 4 12-30-2019 12:23 PM
Need advice on EC Ranger before buying one Stewee64 Enduro Intake/Carburetion - 2 stroke 10 08-03-2019 11:59 PM
Very Good Review on 2020 GasGas Ranger Moto7man Pictures & Videos 0 07-10-2019 04:08 PM
