Old 11-10-2020, 04:38 AM
Beastie Boy's Avatar
Beastie Boy Beastie Boy is offline
Default 2019 EC 300 Air filter Fitting
Changing out the air fiter for the first time
Got a new funnel web and oiled it up.
Fitted it up and at first it sealed ok at the left side but not on the upper side. A bit of wiggling and it seemed to fit better on the top with the black seal surface surface making good contact with the air box.
When I fiited the spring loaded rod it fitted into the platic cup at the back of the airbox but it seems to be at a strange angle.
Hopefully you can see this from the photos. Have i messed up? Is there some tips/ tricks to replacing the filter? Or does it look ok?
[ATTACH][ATTACH][ATTACH][ATTACH]20201110_170612.jpg[/ATTACH][/ATTACH][/ATTACH][/ATTACH]
2019 EC 300
Old 11-10-2020, 04:40 AM
Two more photos
2019 EC 300
Old 11-10-2020, 10:26 PM
Gez Gez is offline
Both my twin air and uni filters do seem to flare up a touch on the flange side like yours. I've found that you need to press down in different locations around the outside edge of the filter towards the engine 3 or 4 times until you feel it isn't seating any further.
I've never had any dust make it through doing it this way, not sure about the spring clip though.
Old 11-11-2020, 03:17 AM
Thnbaks for the feedback....yeah I found I had to keep pushing around the edges to get it to seat
2019 EC 300
Fitting a keyignition to a EC 125 05 Wilmer Enduro Electrical & Wiring 0 01-09-2018 03:27 AM
2000 air filter vs. 2011 filter? nknudsen Enduro Intake/Carburetion - 2 stroke 2 05-22-2014 12:00 PM
AIR FILTER BOX RUBBER and CARB Fitting (ec200 2011 sixd) eliasn101 Enduro Engine - 2 stroke 13 07-12-2013 10:48 AM
Nambotin fitting in well at KTM Keg General Discussions & Announcements 9 01-14-2012 10:07 AM
Fitting map switch to 200? blanc General Discussions & Announcements 7 12-14-2010 07:44 AM
