#11
Speaking of lighter springs...do you think they would (slightly) increase the chance of a stuck throttle ? |
#12
IME with Keihn PWKs a stuck throttle is the result of either dirt inside the carburetor, a worn out carb body (from dirt getting between the slide and carb body) or the plastic throttle cable retainer not being seated correctly.
#13
I tried it and it worked great! Made all the difference and saved me some arm pump on the Baby Burr in Ohio this weekend. I always wondered what that spring was doing on the fuel line. Made me fall in love with the Gasser all over again, then again that happens every time I ride it ;-)
Thanks!
Current Rides: 07 EC250 (Plated, best handling woods bike ever!) 07 525XCW (Plated, dirt and SM) Previous rides: 05 KTM 300EXC, 02 Honda CBR954RR, 01 Ducati 750SS, 99 Suzuki RM250, 98 Kawasaki KX250, 95 Honda CR250R, 95 Suzuki DR350, 97 Yamaha 350 Warrior, 86 Suzuki DS125. |
#14
Here is another option!
When I bought my W.E.C. bike I noticed the throttle was way easier to twist vs. my 04 300. One day I took the carb apart to re-jet. Upon looking at the throttle spring I noticed that the gas gas mechanic for Nambotin had actually cut a small portion of the spring off. This in turn made the throttle pull a bit softer than the normal length spring. So you could always cut small portions of the spring out until you find that desired "Sweet" spot. |
throttle cable | steve | Enduro Intake/Carburetion - 2 stroke | 5 | 02-08-2009 06:17 AM |
Throttle cable | dave948 | Enduro Intake/Carburetion - 2 stroke | 7 | 10-10-2008 04:16 PM |
Throttle problems | Guido / Denmark | Enduro Engine - 2 stroke | 1 | 11-25-2007 10:30 AM |
