How to remove clocks
On my 09 EC 125 I have the red rectangular clocks , but they've never worked since I had the bike , how do the clocks come off so I can maybe try changing the batteries etc
The bracket is fixed to the top triple clamps with a couple of M5(?) screws. If you undo them, I think you will figure out the rest.
I need to remove the headlight assembly to get to this but I can't seem to work out how to remove it 🙄😂
The headlight is fastened by rubber bands around the fork legs. Undo the two rubber bands at the top and the headlight assembly can be lifted up / forward.
You can also probably remove the battery from the underside of the speedo using a coin once the headlight is off
Sent from my iPhone using Tapatalk |
Can I remove my EFI and install a Carb? | safetythird | Enduro Engine 4 stroke (including EFI & Exhaust) | 9 | 10-08-2015 05:14 AM |
How to remove Flywheel? | Fabry | Enduro Engine - 2 stroke | 12 | 08-16-2013 03:27 PM |
How do I change the clocks from KPH to MPH | KTMAndy | Enduro Electrical & Wiring | 5 | 04-20-2012 06:28 PM |
EC200 06 Clocks | jamesfordham | Enduro Electrical & Wiring | 9 | 04-20-2012 03:40 PM |
how do you remove the kickstart | noobi | Enduro Chassis & Body | 13 | 09-22-2011 03:31 PM |
