Old 04-18-2020, 02:33 PM
Dawson Dawson is offline
Default 2011 TXT 300 GG starting propblem
Hi Guys,
My 2011 GG TXT 300 is not starting and was running great up until, I turned it off and now its not starting. Good gas, clean air filter, good spark, reed valves is in great shape and compression is good.
When kicking the bike over, it feels very different and I am not able to give it the hard kick that?s needed for it to start up.
Just looking for some help on troubleshooting this problem, as I am new to gg Trial Bike.
Could the Kickstarter gear be worn-out and require replacement?
Any help will be greatly appreciated.
Thank you
Old 04-18-2020, 03:01 PM
blitz11's Avatar
blitz11 blitz11 is offline
Can you push start it? If so, how does it run then?
Old 04-19-2020, 05:30 AM
That is a great question.
Its my first trial?s bike. Due to high compression and the gearing, it's very difficult to push start this type of bike to the best of my knowledge.
Thank you for your help
Old 04-19-2020, 06:48 AM
hannesd hannesd is offline
try selecting a higher gear,2/3/4th gear...
have someone push you and you stand on the pegs and then dump the clutch.
Old 04-19-2020, 10:18 AM
cbutler's Avatar
cbutler cbutler is offline
https://www.trialscentral.com/forums/
Trials Central if you scroll down as a gas gas specific forum some very knowledgeable gas gas trials guys they'd be glad to help you out. This is more of a off-road forum
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 05-06-2020, 11:56 PM
Dillon Dillon is offline
2018 ec 300. My bike is not charging the battery. I have cleaned all connections and checked all grounds and two fuses that i an awRe of. Any thoughts? Im assuming the stator is buggered up but, i no nothing about this
Old 05-07-2020, 04:26 AM
Get the charge rate measured straight out of the regulator, (still plugged in) I bet you will have voltage drop issues. Get a proper auto electrician to sus it if out of your depth.
You can do voltage drop tests from the negative and positive feeds out of the regulator to where the drop is if so. My mates was losing about a volt across the light relay.
Starting point for N3CJ on 2011 ec 300. Quigs Enduro Intake/Carburetion - 2 stroke 10 02-08-2017 02:42 PM
starting a 2011 EC 300 part out. redrider Parts 28 08-08-2015 02:11 PM
2011 txt 300 starting when hot Glenn General Discussions & Announcements 1 02-23-2013 04:24 AM
Hot starting. nick790 Enduro Intake/Carburetion - 2 stroke 0 04-21-2010 02:44 PM
F-1 Starting! Rick Pictures & Videos 6 12-18-2009 08:14 PM
