Old 06-25-2013, 03:35 PM
mikeh mikeh is offline
Default Power valve Drain
Hi Guys i am workning on my 07 300 gg and noticed that the PV was not draning the oil out the spigot with the hose it looks as if it has been plugged from the start?? It should be free flowing right?. What made me curious i took off the large PV cover that i bought back then and decided to put the orginal Plate back on i always used to drain it by the drain hole provided by the LTR group. Oh And the reason i took the big PV cover off is so i could get more hit does this make sence?
99 EC 250 - Gas Gas- sold
01 TXT 280 Gas Gas
07 EC 300 Gas Gas
88 Honda NX 250
Old 06-25-2013, 09:29 PM
Brian VT Brian VT is offline
I don't think CA allows a PV drain.
I think they want you to remove the cover after each ride and take the spooge to a recycling facility.
Old 06-25-2013, 11:53 PM
djroggen's Avatar
djroggen djroggen is offline
What kind of oil are you running to get accumulation if spooge in the pv cover?!? I had nearly 80 hours with only a slight black residue with the drain plugged.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 06-27-2013, 05:08 PM
good one Brian!! you know cali well i think next year we will have the EPA following us around with ticket book in hand. I use Amzoil and have great results from it. intercepter i think?
01 TXT 280 Gas Gas
07 EC 300 Gas Gas
88 Honda NX 250
Old 06-27-2013, 05:27 PM
The drain should be open. You could jet your bike lean enough that the spooge will be negligible. I run mine a bit rich and I do get some drip out of the drain.
I also run Amsoil Interceptor or Dominator, whichever one I feel like grabbing when I'm in the store. The Dominator, being red, makes it easier to see how much fuel I have in the tank.
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
power valve nut bonkeye Enduro Engine - 2 stroke 4 10-11-2012 06:40 PM
Power Valve Cleaning lordfeyr Enduro Engine - 2 stroke 2 01-24-2010 05:07 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
