Exhaust rubber
in need of a new rubber joint between the front pipe and Q stealth silencer can anyone tell the the size i need, im unable to get to my bike to measure them for the next few days and need to order a new one
Thanks. |
Using one off a KTM.
2011 EC300 Six Days 2010 EC300 Nambotin Replica |
In a pinch, you can use automotive heater hose, or small diameter rad hose. The petroleum will quickly degrade the rubber. Just an option, if you want ride and don't have the correct part.
All healed up, and ready to burn some fat. |
do you know the model bike it is off or the part number?
thanks. |
i would rather not ride than put a temp fix on something but a good idea though thanks. |
I have had a piece of automotive heater hose on mine for just over a year. It's not as temporary as you would think. It has outlasted the OEM piece.
+1 on the heater hose, works great and about 1/10 the cost for really the same thing
trevor |
A chunk of automotive silicone heater hose might be just the answer.
Noah 2000 EC250 with 2011 transformation kit, KYB SSS forks, MN street title 16' Ski-Doo XS Renegade X 1200 4T 16' Specialized Fatboy trail 02' ZRX 1200r R.I.P. 72' Olds 500ci, Batten Heads, Street/Drag car, former CarCraft magazine centerfold (has-been) 15' TW200 |
ok cheers guys i'll have a look round see what i can get but can someone tell me the size as i cant get to the bike for a few days
Can't remember off the top of my head but easy enough to find out, just measure the diameter of the exhaust outlet tube. I remember I did have to heat mine up a bit to get it pliable to fit around, but nice thing is it's tight and doesn't leak any spooge at the joint.
High pitch Squealing from exhaust and exhaust flange????? | Scar13 | Enduro Engine - 2 stroke | 5 | 02-11-2012 11:32 AM |
Rubber straps | Rabbitist | Enduro Chassis & Body | 4 | 06-01-2011 05:10 AM |
Intake rubber | spanner | Enduro Intake/Carburetion - 2 stroke | 4 | 12-23-2010 12:07 PM |
300 ec Intake rubber | Luke12379 | Enduro Intake/Carburetion - 2 stroke | 0 | 03-27-2010 09:34 PM |
