Mc300
Has anybody swapped a 300 top end on to a mc bottom end. I,m not really a big fan of my 300 ,even with the smaller ign and other mods it still does'nt have enough over rev for my liking and I much prefer my mc250. So I'm curious as to what kind of a mix the 300 top end and lighter crank of the mc would end up like. Other mods on the 300 are Motowest pipe. delete reed spacer and head mod. I'm also thinking that an other .5mm base gasket might help move the power up a bit.
Is it an EC or XC head. My '05 with the stock EC head was rev'er.
started out as an ec head then modified to RBD specs
The lower ends are the same with the exception of the primary counterweight being absent on the MC, which has a small spacer. Slightly less flywheel effect, thats all.
The gasket may do a little but all your precision head work is out the window then. Retard the timing a bit and/or try a GG or Doma pipe. |
Ive tried a few pipes on the bike including the Doma.I guess i'll try running the timing at half a degree btdc with a xtra base gasket.I did like the off idle pull with the head mod but found the bike more difficult to start after a stall, kinda like a real open bike.I would like to know who has the lightest piston , I'm guessing a vertex. Maybee we need to start a facts and questions thread to address these kind of things.
When you had your head done, did you retain the stock compression?
The compression was not corrected back to stock ec spec, have to check my notes but i think 15 psi higher.
Wow, that might explain things. Ron told me 200 PSI tops for pump gas. I was 195-200 on my '03. The '07 with .3mm and .5mm gaskets, stock head, runs 185 PSI on the same gauge and revs like a weedwacker. It pulls off idle good so all I would do is correct the squish.
Glen. So I looked at me records.They show a starting comp of 150 psi at sea level with a revised reading of 175 after cutting, this was quantified on two seperate guages.I think we may have inadvertently discovered why Canadian and U.S. market bikes respond differently to L.T. jetting?
Has anyone compared part no.s that'll confirm. |
