Another no spark question...
Well, I'm getting no spark (99 EC300), narrowed it down to the kill switch wire being grounded. From what I know, the kill switch is only grounded when you want to stop the motor, basically the function of the kill switch. I have unplugged the kill switch and traced the ground back to the cdi.
So, I have the CDI making a constant ground for some reason on the kill switch wire. I can unplug all other wires except for the CDI ground and still have about 1 ohm to ground on the kill switch wire going into the CDI. Has anyone ever experienced this? I'm guessing my CDI is just fried, but I was hoping someone might have a bright idea. Thanks for any help! Drew |
Fixed It
It was the CDI, and in case anyone has this problem again:
Resistance between the kill switch wire and the ground wire coming out of the CDI should be around 100k ohms. If there isn't resistance: bad CDI |
Thread Tools | |
Display Modes | |
Fix for no spark | brains | Enduro Electrical & Wiring | 2 | 08-14-2010 12:38 AM |
no spark... | stainlesscycle | Enduro Electrical & Wiring | 9 | 02-17-2010 07:06 PM |
weak spark | tallboy350 | Enduro Electrical & Wiring | 5 | 11-24-2008 08:18 PM |
Spark plug gap???? | Bandit9 | Enduro Engine - 2 stroke | 1 | 08-29-2007 05:26 PM |
weak spark?? | Cruiser | Enduro Engine - 2 stroke | 11 | 07-01-2007 02:26 PM |
