Old 05-28-2010, 08:59 PM
lukemillar's Avatar
lukemillar lukemillar is offline
Default 2003 400 FSE WP Forks
I'm in the middle of stripping my forks to replace the seals and have got a different number of nylon spacers between the 2 fork legs.
The RHS has 1x9mm spacer and 1 x2.5 mm spacer between the fork cap and the spring.
The LHS has 2 x 2.5mm spacers and 1x 1.5mm spacer
So, apart from one fork having 3 spacers and the other only 2, the combined height of the RHS is 3-4mm higher than the LHS!
Is this as WP intended? The parts fiche quotes all three sizes of spacer which I assume is for different preload, but I'm guessing that both forks should be the same!
Any insight would be great
Cheers
Luke
2006 Triumph Daytona 675
2004 Gas Gas 400 FSE
43 mm wp forks. jhendr3702 Enduro Suspension 4 10-18-2010 06:46 PM
forks sen480 General Discussions & Announcements 1 03-25-2010 04:54 AM
which forks have i got?! tommo Enduro Suspension 3 12-29-2009 02:53 PM
