2018 rear axle slot in swingarm
I feel this slot is machined too short - it stops way short of alowing the tire/wheel to be pushed forward to where the tire contacts the shock flap/guard. Cutting that slot only 1/3 inch longer would allow better fine tuning of the wheelbase and, more importantly, make changes to gearing possible without always having to change chain length. Should I attempt to make the slot longer and if so what type of cutter would be best?
Making the slot bigger may weaken the swingarm.
Use a burring bit to remove the aluminum. https://drillsandcutters.com/sa3nf-3-8-x-3-4-cylindrical-carbide-burr-1-4-shank-aluminum/ |
2018 axle block pre-orders | motocenteraz | Enduro Product Announcements | 16 | 02-15-2020 11:50 PM |
2018 swing arm / axle adjuster | chunkysoup | Enduro Chassis & Body | 5 | 05-21-2018 06:47 AM |
Swingarm Axle for EC200 | Kris | Enduro Suspension | 0 | 05-19-2014 07:31 AM |
Swingarm axle question??? | ktmguy23 | Enduro Chassis & Body | 12 | 04-06-2007 11:54 AM |
swingarm axle | wheels7 | Enduro Chassis & Body | 19 | 12-16-2006 09:40 PM |
