Go Back   Rieju & GasGas Legacy Riders Club Forum > General Forums > GasGas Member Polls
GasGas Member Polls Find out what everyone thinks about it!
View Poll Results: Which Steering Damper?
Scott's 26 56.52%
GPR 2 4.35%
WER 7 15.22%
Motorsportz 7 15.22%
Other 5 10.87%
Multiple Choice Poll. Voters: 46. You may not vote on this poll
Old 07-11-2012, 08:51 PM
Edman Edman is offline
Looks like Scotts is the most popular brand.
Old 07-12-2012, 11:21 PM
Do you have to bend up cross bar with Scotts over the bar set-up. Trying to avoid sub mount due to not wanting to raise bars.
Old 07-12-2012, 11:45 PM
GMP, is yours sub mount or over bars mount. I see you have Flex Bars and I may go that route someday.
How about a pic!
Old 07-13-2012, 09:28 AM
GMP's Avatar
GMP GMP is offline
Top mount, I hate submounts and tall bars, like to get up over the front and read my own numberplate! I have long arms though so its comfy for me.
Flexxbars, 10 deg enduro bend with damper crossbars. Scotts damper on adjustable Fastway mount, because I wasn't sure which bar position I would like. I find I like the rear position on the '12, front position on the older bikes. Plus, rear position makes PFP and comp access much easier. I added two 1mm stainless shim washers under each bar mount in addition to the stock aluminum spacer to get my PFP adjusting tool on easy. The tower is my own design(strong) as discussed elsewhere and Scotts arm +10mm longer. The steel dust seal/cup is from the BRP tower and I added an oring under it for a good seal on the edge of the steering neck.
I love the setup. The '12 bike is VERY stable, and I find that the damper has an easy job. I run it full out on low speed which makes the high speed most effective, perfect if needed. Can't do that with a GPR or MotoSportz.
Old 07-13-2012, 11:57 AM
Looks very clean.
Thanks
Steering Stabilizer? singletracker Enduro Chassis & Body 13 12-21-2011 05:03 PM
GPR stabilizer. Ud_luz Enduro Suspension 27 02-25-2008 11:04 PM
