My either Crazy or that knocking /pinging is BAD...
So I got my EC 250 carb cleaned up and on the bike and set up to idle nice and low.. NOW I hear a pinging /knocking sorta like piston head SLAP.. as I rev the Bike up and run her its smooth strong and you can no longer hear the noise.. ( engine is to loud )
However the faster you rev her and before the engine noise gets to loud you and hear that pinging/knocking get faster too. Obviously its either supposed to sound that way ( I some what doubt ) or I have a issue ready for explosion.. NOW I did crank the ec 300 and could BARELY hear it on that bike.. I put fresh OIL so its not oil unless I added to much...( 900 CC but I let it drain while angled on the kick stand residual could have added maybe 100 CC ? ) Silkolene Medium 85-90 Fuel perhaps?? I run only 93 octane and run 50 - 1 Should I look at adding a OCTANE booster?? Maybe its normal and I am crazy.. |
does it do the same when pulling the clutch,at idle?
if so , then it's your clutch basket that's a bit loose. it could allso be the nut on the RHS of the cranckshaft, therefor you need to open the RHS engine cover. |
Most common rattle complaint is play in the power valve mechanism allowing excessive movement at low RPM. Easily adjusted out.
pinging generally SOUNDS like it is coming from the pipe and not the motor. does it sound like it's coming from the front of the pipe? like marbles bouncing around in the pipe? that's the best sound description i can think of for pinging.... knocking is usually something loose... or possibly piston slap. sounds to me like a rh crank nut, clutch hub, nut, or a bearing about to give up. too much oil will have no noise effect - even if you drastically overfilled it, it would just test the seals, and eventually blow something out (but not make a knocking sound) - most regularly put 950ml in anyways (1 quart..) does it sound bad ("oh my god something is gonna let go") or just annoying ("what is that noise?")
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com Last edited by stainlesscycle; 02-13-2012 at 02:43 PM. |
Really depends on how fast "faster you rev her" is. Could be the pipe o-rings too. Did this just start after the carb work? If so what other hardware was R&R?
I honestly can not say I remember it OR do not remember it.. The Bike revved way to high before the carb rebuild to notice it..
I did ride it before the carb rebuild for about 5 hours so I DOUBT anything is going bad, but it sounds to me like it coming from the head/ gear area.. I think I will just slap her on the Jeep and drive her to a shop and let them listen and see what they think.. IF I can Ill see if I can capture it later on Video/sound.. I did Put new reeds on it and replaced the Exhaust Flange O -rings.. Its more of a low knock... |
Found a Video with the Pinging/knocking
http://www.youtube.com/watch?v=IwbHsOk0bY4 He even calls it piston slap... |
My raga trials and my 07 Ec300 both had similar amount of noise as that and both are fine.They are a noisy motor from what I have seen.Some of that noise will quiten when the clutch is pulled (on mine anyway).
Cheers Mark
Xr 250 ( first bike) 98 Rmx 2007 Gas gas 300(swapped for trials bike) 2008 280 Raga replica 2012 Gas gas ec 300 E |
that sound is not pinging. it's either piston slap, or bad small end bearing/pin. sometimes bad big end bearing/pin makes a noise like that too. so it's either slop in the rod at either end, or slap. my it175 makes a noise like that at idle (and my it200 does not make that noise..)- i thought it was slap, rebored, new top end and it's still making the noise. crank bearings seem ok, and big end seemed fine. so if you figure it out, let me know....
07 ec300 was 00 xc200 now a 00 xc300. now parting out. 99 ec300 (now a pile of parts which are for sale) Stainless Cycle - Motorcycle Bolt Kits www.stainlesscycle.com |
http://www.youtube.com/watch?v=X0iKTObBOuQ |
Pinging? | Neil E. | Enduro Engine - 2 stroke | 22 | 04-24-2012 07:44 PM |
Crazy idea... | ruckusman | Enduro Engine - 2 stroke | 2 | 08-25-2011 03:22 AM |
Crazy Cross | noobi | Pictures & Videos | 5 | 01-12-2011 01:31 AM |
knocking noise | stay_upright | Enduro Engine - 2 stroke | 7 | 08-06-2009 03:30 PM |
FAQ Input : Pinging when backing off the throttle. | jeffd | Enduro Engine - 2 stroke | 0 | 08-02-2006 11:47 AM |
