#21
I just assumed he was using F since there wasn't a location in the first post. That makes a pretty significant difference to say the least! It's summertime down under!
#23
sorry lincoln, yep i'm in oz, and its hot and humid around here right now as there is rain to go with the heat at present. Tough conditions on man and machine.
#24
Nothings broken with the way you did it Only really an issue if things are corroded and you have to lean on it.
#25
Cool. thanks Jake.
#26
Same goes for install. Just be aware its only a plastic gear on the back side holding things in position, and don't get too hamfisted.
Should still be able to check the fuel flow with the filter in place. If it doesn't look too good remove the filter and compare the rate of flow. Those little filters can get blocked up over time, especially if filling in rather remote places (or from old jerry cans). |
#27
Sweet thats what I wanted to hear. I have fists of ham so i'll be extra careful. I'm getting prices for an impeller, radiator caps (i dont suppose you'd know what bar the stock radiator caps are?) and one of those inline water coolers, is there anything else anyone could think that i should be getting (other than a 2015 model ) to help my cause?
#28
Plenty of good advice here for you, let me add one more thing to check.
Be sure the antifreeze your using is predeluted. Pure antifreeze will not provide enough cooling. 60% water(distilled) 40% antifreeze will work best.
15 GASGAS EC 250 19 Sherco SE 125R |
#29
Photo in this thread: http://www.gasgasrider.org/forum/sho...=failed+gasket
2005 GasGas EC300 2017 Beta 300RR Race Edition 2021 TM Racing 300EN Fi (2T) |
#30
cheers hamilton, Ive got some liquid intelligence coming for the bike for when its back together.
03 ec300 overheating | waycrazy | Enduro Engine - 2 stroke | 16 | 08-10-2012 12:13 PM |
overheating problem please help | fkmf6 | Enduro Engine 4 stroke (including EFI & Exhaust) | 10 | 07-20-2010 07:41 PM |
Ec 250 Overheating New Piston? | Elliker | Enduro Engine - 2 stroke | 6 | 07-16-2009 04:55 PM |
Overheating 300 in climbing | mariogt | Enduro Engine - 2 stroke | 11 | 12-04-2008 03:49 PM |
A few questions (overheating) | 2 strokes 4 life | Enduro Engine - 2 stroke | 8 | 06-03-2008 09:13 AM |
