#31
If it had a bad enough air leak to make it overheat as easily as you describe it would run like crap. I would replace the radiator cap with the stock 1.8 cap before I did anything else.
#33
agreed. remember going to a higher psi cap, like a ktm, raises the 'highest' operating temp, if you get into that range.
2002 Husberg FE650e 2006 GasGas EC300 2014 Sherco SER300 2014 Beta Evo Factory 300 |
#34
when i'm putting the water pump cover back on do i just bolt it on or do I need to replace the gasket? the gasket looks fine although it looks more like a seal than a gasket. a silly question i know but i want to get it right. cheers.
#35
A silly question deserves a silly answer (or no answer in this case, sorry fellas, mr impatient didnt want to wait for new gaskets to come). Any way ive put it back together (with new gaskets) and a new 1.8 bar radiator cap and while i'm not sure about the overheating issues (as ive only taken it for a short test run) the bike is definitely running better. It used to have a flat spot before it came onto the pipe which no amount of jetting seemed to fix (which i just assumed was the nature of the bike), but that seems to have gone. Id actually say that this is the best this bike has run in the 2 years ive owned it.
#36
Reusing gaskets is one of those things. Some do, some don't. Sometimes it works, other times not. Generally I weigh up the cost vs time/effort/impact if reusing doesn't work. |
#37
So is it still running as it should? What do you think the reason for it was?
#38
Replacing the radiator cap with a new 1.8 bar one seems to have been a very good thing for the bike. Unfortunately, I havent had many opportunities to ride it since I last posted due to work commitments and a ridiculous amount of rain in this part of the world recently. The few times ive got on it it seems ok but i havent had the opportunity for it to get hot enough to potentially overheat as it was previously. Unfortunately this is the latest in an ongoing list of problems Ive had with this bike in the 2 years ive owned it. I'm very hopeful (rather than confident) that ive sorted its issues and i'll have a good period with the bike from here on. I'll keep you posted if I have any more drama's with it.
03 ec300 overheating | waycrazy | Enduro Engine - 2 stroke | 16 | 08-10-2012 12:13 PM |
overheating problem please help | fkmf6 | Enduro Engine 4 stroke (including EFI & Exhaust) | 10 | 07-20-2010 07:41 PM |
Ec 250 Overheating New Piston? | Elliker | Enduro Engine - 2 stroke | 6 | 07-16-2009 04:55 PM |
Overheating 300 in climbing | mariogt | Enduro Engine - 2 stroke | 11 | 12-04-2008 03:49 PM |
A few questions (overheating) | 2 strokes 4 life | Enduro Engine - 2 stroke | 8 | 06-03-2008 09:13 AM |
