Old 05-08-2008, 08:36 PM
eff's Avatar
eff eff is offline
Skid, the .5mm is fine.
2004 GasGas DE250
Old 05-09-2008, 07:38 AM
Eric K Eric K is offline
If you set your squish band close or are very particular about port timing then you need to check your installed dimensions every time you replace the piston. When I put a new piston in my '06 EC300 the top of the new Vertex piston at the outer edge was 0.23 mm higher than the top of the original piston at the outer edge. I set the base gaskets to compensate.
Eric K
'06 GasGas EC300
'01 GasGas XC300
Changing the base gasket... JoeH Enduro Engine - 2 stroke 3 08-28-2009 07:16 AM
!!! Help with Base gasket thickness !!! timlh Enduro Engine - 2 stroke 1 05-14-2009 07:58 PM
thinner base gasket fullthrottle Enduro Intake/Carburetion - 2 stroke 4 06-01-2008 08:09 AM
Base gasket preparation? d2w Enduro Engine - 2 stroke 7 06-25-2007 06:30 AM
Base Gasket gtsnowcrack Enduro Engine - 2 stroke 6 09-09-2006 05:43 AM
